Ich wollte hier mal einen Thread starten, in dem interessante 3D Druck Projekte und Dateien aus Thingiverse gesammelt werden.
Keen-One Harmonic Drive EQ Mount by Kenichi_Aihara
From now on, I will post updates below.https://www.printables.com/model/273812-keen-one-harmonic-drive-eq-mount
Upadated: 7 September 2022
Uploaded Simplest…
www.thingiverse.com
Heavy-duty Equatorial astronomic mount powered by Onstep by Mazikke
Mount is in constant development, not all parts may fit together perfectly, sawing or modification of 3d model may be required. I will be posting updates.
You…
www.thingiverse.com
EQ telescope mount II. for OnStep goto controller by RomanHujer
NOTICE: The new version now released!
EQ mount II for small telescope or DSLR, desing for OnStep goto controller.
How to make? See my video:…
www.thingiverse.com
EQ and 60360Refractor by zug110
EQ mount for small telescope and 60360Refractor.
www.thingiverse.com
HrEM - Harmonic EQ Mount by RomanHujer
HrEM is Harmonic EQ Mount with OnStep controller
Gear ratio is 1 : 404.1818 ( 1+46/11) *78
Source code on GitHub
BOM
2 x 6010ZZ bearing
2 x 6807ZZ…
www.thingiverse.com
6 Inch Newtonian Telescope by Greyman633
Update Jan.29/2021 All my Thingiverse tips are donated to children's charities, so I want to thank those of you who have provided support, and been so…
www.thingiverse.com
Travel EQ Mount by Ulysse31
3D Printed Travel EQ
Status : Beta / Work In Progress
3D Printed Motorised Travelling Equatorial mount compatible with OnStep electronics Project.
The goal is…
www.thingiverse.com
Small Travel 3D printed OnStep EQ mount for telescope by RomanHujer
NOTICE NEW Harmonic drive version is now on HrEM
Sumary
It is new version 3D printed OnStep EQ telescope compact mount for OnStep goto controller, now use…
www.thingiverse.com
Crayford Focuser 2inch by jackleone12
2" focuser for telescope with 40mm travel.
Created to go with the Newtonian Telescope "Newton To See Here" found at…
www.thingiverse.com
2in Crayford Focuser by marcopolomint
2in Crayford Focuser specifically for 3D printing.
download note:
If you are gluing the runners to the drawtube with superglue or epoxy please use CRAY_2in…
www.thingiverse.com
Crayford Focuser 1 1/4 inch by scbeme
1 1/4" Crayford Focuser
Here's my affordable, light-weight 1 1/4" focuser I designed for my 8" Newtonian reflector. Use 'as is' or customize to meet your…
www.thingiverse.com
Customizable Helical Crayford Focuser for Newtownian Telescope by robsch
This is a helical Crayford Focuser for use with an amateur Newtonian telescope. It is made for 1¼″ eyepieces, but can be customized easily to accept 2"…
www.thingiverse.com
Helical Crayford Focuser for Newtonian Telescope by Buback
The Crayford design allows for fine, smooth adjustment in focus, and doesn't require the focuser tube to have a rack machined into it, so it's ideal for…
www.thingiverse.com
StubScope - 70mm Telescope with 2" Crayford Focuser by StubMandrel
This is a complete set of prints for a 70mm aperture wide-field astronomical telescope.
It is an advanced build as you will need to do some basic engineering…
www.thingiverse.com
Crayford focuser - upgrade for cheap focuser on your telescope by curly_cz
Upgrade for cheap foucuser on Omegon 130mm newtonian scope. There is a probability that it is compatible with another scopes - check your screw layout or feel…
www.thingiverse.com
Helical Crayford Focuser - v2 by Buback
This Focuser is adjustable, in that you can use various diameter focuser tubes (within a certain range). It can be tough to source the proper sized tube in…
www.thingiverse.com
Gruß Play
