Hi Ulrich,
sorry f.d. späte Antwort - ich habe es gestern Abend nicht mehr geschafft...
Ich bin mir nicht sicher, ob Dir meine Settings helfen - ich habe scheinbar eine recht alte Software-Version. Ich benutze eine ZWO ASI178MC Color - wenn Du eine andere Kamera hast,
kann sich Auto-Gain und Exposure natürlich anders benehmen.
Hier meine config.sh:
Bash
#!/bin/bash
# NOTES:
# - Variable names must start at the beginning of a line.
# - There should be nothing after a variable's value, i.e., no comments on the same line.
# - Values can optionally be quoted with double quotes, NOT single quotes.
# - If a variable occurs multiple times, only the last value is used.
# Choose between "ZWO" or "RPiHQ".
CAMERA="ZWO"
PIX_FMT="yuv420p"
########## Images
# Set to "true" to upload the current image to your website.
IMG_UPLOAD="true"
# If IMG_UPLOAD is "true", upload images every IMG_UPLOAD_FREQUENCY frames, e.g., every 5 frames.
# 1 uploades every frame.
IMG_UPLOAD_FREQUENCY=1
# The websites look in IMG_DIR for the current image.
# When using the Allsky website from the "allsky-website" packge,
# "current" is an alias for "/home/pi/allsky".
# If you use the default IMG_DIR and have the Allsky website, set "imageName" in
# /var/www/html/allsky/config.js to:
# imageName: "/current/tmp/image.jpg",
# This avoids copying the image to the website.
# Only change IMG_DIR if you know what you are doing.
IMG_DIR="current/tmp"
# Resize images before cropping, stretching, and saving.
# Adjust IMG_WIDTH and IMG_HEIGHT according to your camera's sensor ratio.
IMG_RESIZE="false"
IMG_WIDTH=2028
IMG_HEIGHT=1520
# Crop images before stretching and saving.
# This is useful to remove some of the black border when using a fisheye lens.
# If you crop an image you may need to change the "Text X" and/or "Text Y" settings in the WebUI.
CROP_IMAGE="false"
CROP_WIDTH=640
CROP_HEIGHT=480
CROP_OFFSET_X=0
CROP_OFFSET_Y=0
# Auto stretch images saved at night.
AUTO_STRETCH="false"
AUTO_STRETCH_AMOUNT=10
AUTO_STRETCH_MID_POINT="10%"
# Resize uploaded images. Change the size to fit your sensor.
RESIZE_UPLOADS="false"
RESIZE_UPLOADS_SIZE="3096x2080"
# Create thumbnails of images. If you are not running the WebUI consider changing this to "false".
IMG_CREATE_THUMBNAILS="true"
# Remove corrupt images before generating keograms, startrails, and timelapse videos.
# This only adds a few seconds per image as it's being processed.
REMOVE_BAD_IMAGES="true"
# If REMOVE_BAD_IMAGES is "true", images whose mean brightness is
# less than THRESHOLD_LOW or greater than THRESHOLD_HIGH percent (max: 100) will be removed.
# Set to 0 to disable the brightness checks.
REMOVE_BAD_IMAGES_THRESHOLD_LOW=1
REMOVE_BAD_IMAGES_THRESHOLD_HIGH=90
# Additional Capture parameters. Run "capture_RPiHQ -h" to see the options.
# e.g. activate autoexposure algorithm "mean" for RPiHQ: "-mean-value 0.3 -autoexposure 1"
CAPTURE_EXTRA_PARAMETERS=""
# Set to "false" to disable daytime capture.
DAYTIME_CAPTURE="true"
# Night images are always taken and saved to disk.
# Setting DAYTIME_SAVE to "true" also saves daytime images to disk.
# Will only save daytime images if DAYTIME_CAPTURE="true".
DAYTIME_SAVE="false"
########## Timelapse
# Set to "true" to generate a timelapse video at the end of each night.
TIMELAPSE="true"
# Set the image width and height for timelapse video (sizes must be divisible by 2).
TIMELAPSEWIDTH=0
TIMELAPSEHEIGHT=0
# Bitrate of the timelapse video. Higher numbers will produce higher quality but larger files.
TIMELAPSE_BITRATE="2000k"
# Timelapse video Frames Per Second.
FPS=25
# Encoder for timelapse video. May be changed to use a hardware encoder or different codec.
VCODEC="libx264"
# FFLOG determines the amount of log information displayed while creating a timelapse video.
# Set to "info" to see additional information if you are tuning the algorithm.
FFLOG="warning"
# While creating a timelapse video, a sequence of links to the images is created.
# Set to "true" to keep that sequence; set to "false" to have it deleted when done.
KEEP_SEQUENCE="false"
# Any additional timelapse parameters. Run "ffmpeg -?" to see the options.
TIMELAPSE_EXTRA_PARAMETERS=""
# Set to "true" to upload timelapse video to your website at the end of each night.
UPLOAD_VIDEO="true"
########## Keogram
# Set to "true" to generate a keogram at the end of each night.
KEOGRAM="true"
# Additional Keogram parameters. Run "keogram --help" to see the options.
KEOGRAM_EXTRA_PARAMETERS="--font-size 1.0 --font-line 1 --font-color '255 255 255'"
# Set to "true" to upload the keogram to your website at the end of each night.
UPLOAD_KEOGRAM="true"
########## Startrails
# Set to "true" to generate a startrails image of each night.
STARTRAILS="true"
# Images with a brightness higher than this threshold will be skipped for
# startrails image generation. Values are 0.0 to 1.0.
BRIGHTNESS_THRESHOLD=0.1
# Any additional startrails parameters. Run "startrails --help" to see the options.
STARTRAILS_EXTRA_PARAMETERS=""
# Set to "true" to upload the startrails image to your website at the end of each night.
UPLOAD_STARTRAILS="true"
########## Other
# Size of thumbnails.
THUMBNAIL_SIZE_X=100
THUMBNAIL_SIZE_Y=75
# Set to "true" to enable automatic deletion of archived data (images + videos).
AUTO_DELETE="true"
# If AUTO_DELETE="true", set this value to the number of archived nights you want to keep.
NIGHTS_TO_KEEP=14
# Set to "true" to upload data to your server at the end of each night.
# This is needed if you are running the Allsky Website.
POST_END_OF_NIGHT_DATA="true"
# Set to "true" if you want to enable dark frame subtraction on your night-time images.
# You must first create dark frames - see the README.md file for instructions.
DARK_FRAME_SUBTRACTION="false"
# If you have a fan in your Allsky camera enclosure that reports its speed,
# set this to the full pathname of that file.
# The file should include two numbers: the fan speed in RPM and the percent of maximum speed.
FAN_DATA_FILE=""
# The uhubctl command can reset the USB bus if the camera isn't found and you know it's there.
# Allsky.sh uses this to try and fix "missing" cameras.
# Specify the path to the command and the USB bus number (on a Pi 4, bus 1 is USB 2.0 and
# bus 2 is the USB 3.0 ports). If you don't have 'uhubctl' installed set UHUBCTL_PATH="".
UHUBCTL_PATH=""
UHUBCTL_PORT=2
# Path to the camera settings (exposure, gain, delay, overlay, etc) files.
# Do not change unless you know what you are doing.
CAMERA_SETTINGS_DIR="/etc/raspap"
# ================ Do not change anything below this line.
END_OF_USER_SETTINGS="true" # During upgrades, stop looking for variables here.
if [ "${CAMERA}" = "" ]; then
echo "${RED}ERROR: Please set CAMERA in config/config.sh${NC}"
sudo systemctl stop allsky
exit 100
fi
Alles anzeigen
und hier die Kamera-Settings (pdf, link zu meinem webspace)
Vielleicht hilft es ja...
