2 Meter aufs ISS(mit Crewlock Joint)
  • ISS-Quest Airlock observation(labeled)
    http://www.cloudynights.com/ub…rlock_20080925_duot3s.jpg
    Hi all,
    Labeled version of the Joint Airlock(Quest)with the wider Equipment Bay
    and the Crew Compartment.As this Crew Lock is around only 2 metres wide,
    it's a good chance to see what is 2 metres in the image,see labels.
    Though note that due to shading effects not the entire width is visible,making it
    appearing a little more elongated.Thus,the marked 2 metres is a minimal
    marked distance(actually its wider in the image).
    The Crew Lock is the part which is depressurised to a vacuum so that
    the spacewalkers can exit the Hatch.The wider Equipment Lock is used
    for the preparations(like putting on the Spacesuits)
    Many thanks for the interest.All interest and every single reply is much appreciated!
    Ralf Vandebergh
  • <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">Zitat:<hr height="1" noshade id="quote"><i>Original erstellt von: Ralf Vandebergh</i>
    <br />
    Ralf Vandebergh
    Ralf,
    I used your photos as an example when I explained colleagues about astrophotography. The thing I heard most was "People can do THAT? From Earth?"
    Best,
