Observation Tiros 2: Wetter-Satellit aus 1960
  • siehe:
    http://www.cloudynights.com/ub…Tiros2-ISS_20080929ts.jpg
    Hi all,
    See this as my own personal imaging-contribution to more then 50 years spaceflight and NASA's 50th anniversary;
    Last spring I started to search for the oldest spacecraft still in the Earths orbit which I would be able
    to capture.My interest already quickly pointed to the series of Tiros satellites(Television Infrared
    Observation System)from the early 1960's.
    These satellites are really legendary as they are the first succesfull weather-imaging satellites in history.
    The oldest satellite I imaged so far was a rocket body from the late 1970's.
    I spent a lot of observing-time during the summer trying to observe a Tiros satellite but constantly I failed
    due to different factors;faint appearance,no transparant skies at the right moment,no favourable passes,
    simply not visible and so on.Though,I never gave up trying,until I finally succeeded on September 29 observing
    a rare good pass of the Tiros 2 (at magnitude 3.2.I was amazed by seeing a satellite launched in the same
    year as the legendary Echo 1 satellite(1960),with the difference that the Echo already burned up in 1968 and the
    Tiros is still in the Earth's orbit,although it failed to function on January 22, 1961. If we could travel to the Tiros 2,
    we would find there 2 old videocamera's(one low resolution/one high resolution)a magnetic tape recorder and
    different infrared instruments.
    Ok,I wasn't be able to find a satellite from 1957 to show the full 51 years spaceflight but this small 42inch by 19inch
    satellite comming from a time before manned-spaceflight was existing,compared to the largest space-structure
    from today,is still an exciting show I think....
    All images taken by manually tracking using a 10inch Newtonian reflector)
    Ralf Vandebergh
  • Hallo Ralf
    Wow, das ist wirklich der Oberhammer! Das Foto vom Tiros ist zwar in Bezug auf die Auflösung nicht gerade sehr Überwältigend, aber wenn man sich vorstellt wie klein der ist, dann ist es überhaupt ein "Wunder", dass Du ihn erwischt hast!
    Was ich noch viel gewaltiger finde als das eigentliche Foto, ist die Kombination vom Tiros mit der ISS!
    Gewaltig in Bezug auf mehrere Punkte:
    1. Der Altersunterschied von knapp 50 Jahren
    2. Der Grössenunterschied von ca. 1:70
    3. Dieses Foto ist ein würdiges Geburtstagsgeschenk an die NASA!
    Viele Grüsse,
    Sandro
  • Hallo Sandro,
    Danke sehr.Genau so habe ich das auch gesehen.Mehr als ein winziges Scheibchen dürfte mann bei der Tiros auch nicht erwarten,und hatte ich auch nicht erwartet.Im gegenteil:Ich war sehr verwundert das überhaupt nog mehr als ein Punkt zu sehen war.Sterne,aufgenommen mit die gleiche Vergrösserung erscheinen deutlich punktförmiger!Nicht ist er nur 1 bij 1 1/2 Meter Gross,er befindet sich auch nog einige hunderd Km höher als die ISS.Der überflug von Tiros 2 ist bei mir rund 60 Grad Maximum,das gilt eigentlich für alle Tiros Satelliten.Es geht wirklich um die Darstellung und das Gefühl so ein alten satelliten gesehen zu haben!
    viele Grüsse,
    Ralf
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">Zitat:<hr height="1" noshade id="quote"><i>Original erstellt von: Sandro</i>
    <br />Hallo Ralf
    Viele Grüsse,
    Sandro
  • Danke sehr.Hier ein Bild des Aufnahme-Gerätes:
    http://img110.imageshack.us/img110/4720/10inchnewtonkj8.jpg
    Viele Grüsse,
    Ralf
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">Zitat:<hr height="1" noshade id="quote"><i>Original erstellt von: brennus</i>
    <br />gratulation zum heutigen apod !
    http://apod.nasa.gov/apod/ap081016.html
