I am getting out of binoviewers business tottaly, becasue my wife get ill, she get leukemia, and I want spent more time with my family!
So, when items are sold out, they will dissapear from binoviewers market, so grab your chance before they dissapear frever!
6 PIECES WERE AVAILABLE FOR SALE!
(5 pieces already sold)
This is most successful and most selling Carl Zeiss binoviewers with LARGE all prisms inside!
Not without reason: big prisms enough which allow using any 1.25 inch eyepeices without any vignetting in whole FOV, very affordable price, and most important, high quality optics and mechanics, all Made in Germany!
This is exact model on which is based Baader Mark V binoviewer, so Mark V is just COPY of these binoviewers!
Collimation is setted on 100%, and if needed to adjust, can be done very easily with only simple shifting eyepeice holders plates!
Binoviewer is already SUPERCHARGED!
With Supercharge Service:
- you absolutely do not loose in opticall performance
- performance is not affected by anything like additional internal reflections or simillar
- you get more Clear Aperture in your binoviewer
- you can catch more light, especially if you use shorter focal lenght telescopes
- you are able using longer focal lenght eyepeices with bigger FOV
Specifications:
- high quality all metal design of binobody
- easy collimation possible
- high quality all prisms
- high quality polished all prism surfaces
- high light transmittion
- all prims system inside
- all prisms edges are additionally BLACKENED
- prisms diameter is 30mm
- 30mm Clear Aperture (SUPERCHARGED), instead 28mm Clear Aperture originally on left eyepeice side
- 28mm Clear Aperture (SUPERCHARGED), instead 26mm Clear Aperture originally on right eyepeice side
- 30mm Clear Aperture (SUPERCHARGED), instead 28mm Clear Aperture originally on telescope side
- NO ANNOYING POLARISATION EFFECT LIKE COMMON BINOVIEWERS HAVE
- SUPER STRONG, REAL SELF CENTRING, 1.25 inch eyepiece holders, modified and installed with help of CNC machines
- eyepeice holders have inner compression ring which holds eyepeices in center
- compression ring is WIDE, and it is made from PETF material, so locking eyepeices inside holders does not leave any marks on your eyepieces
- T2 bayonet connection on the telescope side, and accepts originally Baader GPCs
- IPD (interpupilar distance): from 55mm to 75mm
- light path: 11.9cm
- weight: 700 grams
Binoviewer is ready for usage in any telescope!
In setup are included:
- 1x Carl Zeiss binoviewer Made in Germany
- 1x Baader Quick Changer (T2 female - Zeiss Micro Bajonet)
- 1x Baader T2 to 1.25 inch adapter
- 1x 1.25 inch plastic male protective cover for back side of binoviewer
- 2x 1.25 inch plastic female protective covers for front side of binoviewer
Supercharge certificate included and signed by me (showed on last pictures in ad).
Included lifetime support, free cleaning, free collimation, and I can provide you free collimation instructions if needed!
Real Carl Zeiss optics and mechanics, so no compromise!
Price 697 euros include fully tracked airmail priority worldwide shipping.
Contact me denis0007 att gmail.com
Kind regards and all best
Denis, binoviewers expert
