2 PIECES AVAIABLE FOR SALE!
For sale HIGH QUALITY, real Carl Zeiss creamy white binoviewers!
Binoviewers are already SUPERCHARGED and MODIFIED!
These are model on which is based Baader Mark V binoviewer, so Mark V is just COPY of these binoviewers!!
Items are in excellent condition, optically and mechanically, especially for its age!
These are NOT GREY old ones, these are LAST run from Zeiss before they were discounted forever!
Eyepeice holders are real self centring, modified and installed with help of CNC machines.
Mechanics works extremly shooth and precise.
Collimation is setted on, and if needed to adjust, can be done very easily with only simple shifting eyepeice holders, so no need shifting and touching prisms, which is common problem with Mak V.
Binoviewers are ready for usage in any telescope!
In setup are included Baader Quick Changer (T2 female - Zeiss Micro Bajonet) and Baader T2 to 1.25 inch adapter - all shown on picture in ad.
With Supercharge service:
--you absolutely do not loose in opticall performance
--performance is not affected by anything like internal reflections and simillar
--opticall performance is improved a LOT, and you get much more Clear Aperture on your binoviewer
--you can catch more light from your fast scopes
--you are able using longer focal lenght eyepeices with bigger FOV.
Specifications:
---REAL SELF CENTRING, super strong 1.25 inch eyepiece holders
---30mm prisms
---NO ANNOYING POLARISATION EFFECT LIKE COMMON BINOVIEWERS HAVE!!
---on left eyepiece side there is 30mm CA prisms (Supercharged), while on Mark V it is 28mm CA
---on right eyepiece side there is 28mm CA prisms(Supercharged), while on Mark V it is 26mm CA
---on telescope side you have full 30mm CA prisms (Supercharged), while on Mark V it is 28mm CA
---T2 bayonet connection on the telescope side, and accepts originally Baader GPCs
---all metal design
---easy collimation possible
---accepts Baader GPCs (simply screw them on back side of binoviewer, same like on Mark V
Buying an item, you have lifetime support and service like free collimation, explanation how to do collimation by yourself at home easily (noone in world wont give you such explanations supported with pictures), and you get free lifetime cleaning or any repair if needed if I can fix.
Real Carl Zeiss optics and mechanics, so no compromise!
Satisfaction guaranteed!
Price include fully tracked airmail worldwide shipping.
Contact denis0007dl att gmail.com
Kind regards and all best
Denis, binoviewers expert
