Hallo Spechtelfreunde,
Skywatcher hat ein Firmware Udate für die SyncScan HandControl veröffentlicht. Die Version 3.3" Beta 29 verfügt nun auch über eine Routine für das Polalignment und kann hier http://www.skywatcher.com/swti…d=124&class1=1&class2=101 heruntergeladen werden. Ich habe das Update bereits durchgeführt und werde --sobald das Wetter wieder einmal eine Beobachtungsnacht zulässt-- über meine Erfahrungen berichten.
Zur Vereinfachung habe ich für alle hier die englische Anleitung für das Polalignment kopiert:
SynScan® EQ GOTO Polar Re-alignment Instruction
- No polar scope polar alignment
Rev. 1.1
INSTRUCTIONS:
1. Level the tripod of the EQ GOTO mount and point to the north or south if in the south
hemisphere.
2. Rough align the RA axis of the mount to the celestial polar axis by pointing to the
north or south and setting the latitude on the EQ mount.
3. Do a 2-Star alignment or 3-Star alignment with the SynScan hand control. 3-Star
alignment is recommended for better accuracy and error compensation. If use 2-Star
alignme nt to align the GOTO mount, please make sure that the “cone error” is
eliminated.
4. After completing the Star alignment, browse to “Polar Re-align.>” submenu
under Setup \Alignment menu of the hand control and then press ENTER.
5. The hand control will prompt, “Select any star:” and provide a list of stars,
which can be used as the reference star for the Polar Re-alignment. Select a star from
the list and press ENTER. The EQ Telescope GOTO mount will slew and point to the
selected object.
6. When the hand control prompt, “ALIGN OBJECT ”, use the directional keys to center
the selected reference star to the center of the finder scope and then to the center of the
eyepiece. When done, press ENTER to confirm. The hand control will prompt the
displacements of polar misalignment of the EQ mount, Mel and Maz, in both elevation
and azimuth directions respectively.
7. Press ENTER and then the mount will slew to the same reference star again, but the
reference star will not locate at the center of the eyepiece at this moment. Try to use the
Altitude Adjustment T-bolts and the Azimuth Adjustment Knobs to adjust the mount as
doing the adjustment for polar alignment, but just draw back and center the reference
star to the center of the eyepiece. In this procedure, you cannot use the directional keys
to center the object and the directional keys are disabled to driving the motors.
8. When finish the adjustment of the mount for the Polar Re-alignment. Press ENTER to
confirm and check the new calculated polar misalignment, Mel and Maz. Press
ENTER to exit Polar Re-alignment function. During these Polar Re-alignment
procedures, you may press ESC to go back to previous step, if necessary.
9. Check the polar re-alignment result. You may repeat the Polar Re-alignment
procedures from step 3 to step 8 to get better polar alignment, if it is necessary.
