Beiträge von Gavva im Thema „PHD 2“
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">Zitat:<hr height="1" noshade id="quote"><i>Original erstellt von: BergAstro</i>
<br />Lade dir doch den LogViewer runter: https://openphdguiding.org/phd2-log-viewer/
Damit kannst du die PHD2-Daten perfekt analysieren. Ich habe das mal mit deinen Daten gemacht: deine Montierung bewegt sich beim Kalibrieren immer in der gleichen Richtung, egal ob PHD2 Impulse für RA oder DEKL sendet!
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">Danke für die Mühe. Sehr nett von dir. Oha, was könnte die Ursache sein? Und wie kann ich das beheben?
LG
Gavva
Guiding Begins at 2021-01-09 22:33:11
Equipment Profile = Touptek
Dither = both axes, Dither scale = 1.000, Image noise reduction = none, Guide-frame time lapse = 0, Server enabled
Pixel scale = 3.87 arc-sec/px, Binning = 1, Focal length = 200 mm
Search region = 25 px, Star mass tolerance = 99.0%, Single-star mode
Camera = GCMOS01200KMB, gain = 0, full size = 1280 x 960, no dark, no defect map, pixel size = 3.8 µm
Exposure = 1000 ms
Mount = On Camera, connected, guiding enabled, xAngle = 121.1, xRate = 27.181, yAngle = -53.8, yRate = 26.519, parity = ?/?
Norm rates RA = 105.1"/s (==>) dec 0, Dec = 102.6"/s; ortho.err. = 85.0 deg
X guide algorithm = Hysteresis, Hysteresis = 0.250, Aggression = 0.850, Minimum move = 0.500
Y guide algorithm = Hysteresis, Hysteresis = 0.250, Aggression = 0.800, Minimum move = 0.500
Backlash comp = enabled, pulse = 20 ms
Max RA duration = 2500, Max DEC duration = 2500, DEC guide mode = Auto
RA Guide Speed = Unknown, Dec Guide Speed = Unknown, Cal Dec = Unknown, Last Cal Issue = Orthogonality, Timestamp = 09.01.2021 22:33:11
RA/Dec = Unknown, Hour angle = Unknown, Pier side = Unknown, Rotator pos = N/A, Alt = Unknown, Az = Unknown
Lock position = 289.369, 509.231, Star position = 289.369, 509.231, HFD = 6.75 px
Frame,Time,mount,dx,dy,RARawDistance,DECRawDistance,RAGuideDistance,DECGuideDistance,RADuration,RADirection,DECDuration,DECDirection,XStep,YStep,StarMass,SNR,ErrorCode
1,2.118,"Mount",3.821,-6.277,-7.348,-7.317,-4.685,-4.390,172,E,166,N,,,130,7.89,0
2,4.449,"Mount",7.939,-11.817,-14.219,-14.103,-10.060,-9.340,370,E,352,N,,,173,9.05,0
3,7.219,"Mount",12.025,-18.810,-22.318,-22.181,-16.365,-15.176,602,E,572,N,,,183,9.57,0
4,10.519,"Mount",17.131,-26.748,-31.753,-31.555,-23.720,-21.968,873,E,828,N,,,180,9.23,1
5,14.432,"Mount",24.053,-35.486,-42.810,-42.445,-32.332,-29.860,1189,E,1126,N,,,173,9.30,1
6,19.045,"Mount",32.520,-44.965,-55.300,-54.679,-42.124,-38.780,1550,E,1462,N,,,180,9.49,1
7,24.490,"Mount",42.303,-56.203,-69.976,-69.072,-53.561,-49.199,1971,E,1855,N,,,153,8.47,0
8,30.859,"Mount",54.344,-68.900,-87.068,-85.768,-66.888,-61.301,2461,E,2312,N,,,181,9.51,1
9,37.457,"Mount",67.512,-83.414,-106.298,-104.591,-81.979,-75.015,2500,E,2500,N,,,159,8.92,0
10,44.055,"Mount",81.468,-97.911,-125.921,-123.745,-97.695,-89.250,2500,E,2500,N,,,169,8.93,1
11,50.669,"Mount",95.105,-111.862,-144.911,-142.269,-113.141,-103.211,2500,E,2500,N,,,152,8.45,1
12,57.284,"Mount",109.123,-126.191,-164.422,-161.299,-128.861,-117.422,2500,E,2500,N,,,175,9.35,1
13,63.908,"Mount",122.521,-139.858,-183.045,-179.462,-144.074,-131.161,2500,E,2500,N,,,190,9.75,0
14,70.512,"Mount",136.218,-153.670,-201.947,-197.887,-159.357,-144.964,2500,E,2500,N,,,162,9.00,1
15,77.126,"Mount",150.038,-167.638,-221.048,-216.507,-174.781,-158.897,2500,E,2500,N,,,167,9.14,1
16,83.719,"Mount",163.256,-181.669,-239.889,-234.917,-190.070,-172.730,2500,E,2500,N,,,176,9.38,0
17,90.314,"Mount",176.344,-195.814,-258.762,-253.374,-205.351,-186.570,2500,E,2500,N,,,155,8.53,0
18,96.909,"Mount",190.511,-209.794,-278.051,-272.156,-220.895,-200.608,2500,E,2500,N,,,174,9.33,1
19,103.496,"Mount",204.397,-223.974,-297.366,-290.994,-236.511,-214.718,2500,E,2500,N,,,171,9.25,0
20,110.104,"Mount",218.327,-238.192,-316.736,-309.886,-252.178,-228.875,2500,E,2500,N,,,128,8.00,1
21,116.705,"Mount",232.124,-251.355,-335.134,-327.772,-267.236,-242.438,2500,E,2500,N,,,132,7.86,1
22,123.338,"Mount",245.458,-265.466,-354.105,-346.306,-282.529,-256.271,2500,E,2500,N,,,106,7.11,0
23,130.036,"Mount",259.215,-279.686,-373.387,-365.124,-298.072,-270.328,2500,E,2500,N,,,156,8.83,1
24,136.641,"Mount",272.364,-293.355,-391.884,-383.179,-313.166,-283.973,2500,E,2500,N,,,146,8.54,1
25,143.270,"Mount",286.095,-307.553,-411.134,-401.966,-328.646,-297.974,2500,E,2500,N,,,177,9.41,0
26,149.866,"Mount",299.107,-321.170,-429.516,-419.915,-343.654,-311.544,2500,E,2500,N,,,147,8.57,1
27,156.491,"Mount",313.212,-334.427,-448.153,-438.020,-358.724,-325.121,2500,E,2500,N,,,143,8.46,1
28,163.108,"Mount",326.872,-348.799,-467.516,-456.932,-374.270,-339.183,2500,E,2500,N,,,162,9.00,0
29,169.712,"Mount",340.473,-362.451,-486.231,-475.170,-389.505,-352.939,2500,E,2500,N,,,164,9.06,1
30,176.311,"Mount",354.354,-377.012,-505.870,-494.349,-405.262,-367.197,2500,E,2500,N,,,155,8.80,1
31,182.916,"Mount",368.169,-390.769,-524.786,-512.776,-420.669,-381.105,2500,E,2500,N,,,160,8.94,1
32,189.520,"Mount",381.249,-404.946,-543.683,-531.258,-435.990,-394.976,2500,E,2500,N,,,165,9.08,1
33,196.123,"Mount",394.681,-418.753,-562.443,-549.562,-451.205,-408.732,2500,E,2500,N,,,161,8.97,1
34,202.744,"Mount",408.572,-432.119,-581.064,-567.671,-466.309,-422.349,2500,E,2500,N,,,169,9.19,1
INFO: Guiding parameter change, MultiStar = false
INFO: Guiding parameter change, MountGuidingEnabled = false
35,209.354,"Mount",421.821,-445.961,-599.761,-585.926,-481.438,-436.026,2500,E,2500,N,,,163,9.03,1
36,210.958,"Mount",435.406,-459.384,-618.271,-603.952,-496.454,-449.576,0,,0,,,,151,8.69,1
37,212.591,"Mount",438.909,-464.434,-624.406,-610.028,-503.555,-455.932,0,,0,,,,187,9.67,1
38,214.230,"Mount",442.054,-469.288,-630.186,-615.769,-508.749,-460.648,0,,0,,,,142,8.43,1
39,215.864,"Mount",445.319,-474.060,-635.958,-621.490,-513.532,-465.024,0,,0,,,,157,8.61,0
40,217.504,"Mount",447.807,-479.071,-641.535,-627.086,-518.104,-469.256,0,,0,,,,160,8.64,0
41,219.137,"Mount",450.655,-483.938,-647.173,-632.709,-522.670,-473.477,0,,0,,,,167,9.14,1
42,220.790,"Mount",454.781,-488.201,-652.955,-638.351,-527.326,-477.706,0,,0,,,,167,9.14,1
43,222.423,"Mount",457.695,-494.155,-659.558,-644.980,-532.525,-482.529,0,,0,,,,158,8.89,1
44,224.053,"Mount",460.499,-498.900,-665.069,-650.474,-537.143,-486.790,0,,0,,,,166,9.11,1
45,225.674,"Mount",463.245,-503.851,-670.727,-656.128,-541.731,-491.035,0,,0,,,,150,8.66,1
46,227.335,"Mount",466.506,-507.398,-675.449,-660.747,-545.717,-494.655,0,,0,,,,96,6.93,1
47,228.950,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
48,230.717,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
49,232.452,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
INFO: Guiding parameter change, MountGuidingEnabled = true
50,234.206,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
51,235.942,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
Guiding Ends at 2021-01-09 22:37:08
INFO: Guiding parameter change, MultiStar = falseGuiding Begins at 2021-01-09 22:37:37
Exposure = 1000 ms
Lock position = 273.613, 154.113, Star position = 273.613, 154.113, HFD = 5.68 px
1,2.088,"Mount",4.014,-5.960,-7.177,-7.118,-4.575,-4.271,168,E,161,N,,,59,5.43,1
2,4.031,"Mount",7.240,-10.670,-12.876,-12.766,-9.181,-8.514,338,E,0,,,,61,5.52,1
3,5.631,"Mount",11.375,-16.825,-20.283,-20.112,-14.881,-13.770,0,,0,,,,80,6.32,1
4,7.263,"Mount",13.738,-22.191,-26.097,-25.970,-19.799,-18.336,0,,0,,,,77,6.20,1
5,8.892,"Mount",16.066,-26.943,-31.369,-31.262,-24.205,-22.424,0,,0,,,,53,5.15,1
6,10.528,"Mount",20.039,-30.968,-36.868,-36.623,-28.647,-26.459,0,,0,,,,69,5.87,1
7,12.171,"Mount",23.641,-35.972,-43.013,-42.700,-33.508,-30.912,0,,0,,,,71,5.96,1
8,13.804,"Mount",25.847,-40.573,-48.093,-47.803,-37.780,-34.864,0,,0,,,,63,5.61,1
9,15.452,"Mount",29.523,-46.045,-54.677,-54.333,-42.884,-39.573,0,,0,,,,59,5.43,1
10,17.102,"Mount",32.214,-50.248,-59.665,-59.291,-47.149,-43.489,0,,0,,,,52,5.10,1
11,18.737,"Mount",35.079,-55.528,-65.667,-65.294,-51.882,-47.874,0,,0,,,,65,5.70,0
12,20.369,"Mount",38.661,-60.435,-71.719,-71.275,-56.746,-52.340,0,,0,,,,62,5.57,1
13,22.000,"Mount",42.069,-65.507,-77.822,-77.328,-61.670,-56.865,0,,0,,,,66,5.74,1
14,23.653,"Mount",44.860,-70.518,-83.554,-83.056,-66.371,-61.207,0,,0,,,,74,6.08,1
15,25.283,"Mount",47.640,-74.900,-88.742,-88.213,-70.677,-65.169,0,,0,,,,75,6.12,1
16,26.912,"Mount",51.133,-79.825,-94.763,-94.172,-75.431,-69.537,0,,0,,,,59,5.43,1
17,28.538,"Mount",54.325,-84.738,-100.619,-99.988,-80.174,-73.900,0,,0,,,,64,5.66,1
18,30.174,"Mount",57.419,-89.790,-106.544,-105.886,-84.959,-78.312,0,,0,,,,62,5.57,1
19,31.808,"Mount",60.184,-95.191,-112.596,-111.952,-89.834,-82.834,0,,0,,,,64,5.66,0
20,33.440,"Mount",62.991,-99.975,-118.142,-117.483,-94.405,-87.057,0,,0,,,,58,5.39,0
21,35.072,"Mount",66.860,-105.099,-124.529,-123.786,-99.448,-91.683,0,,0,,,,74,6.08,1
22,36.700,"Mount",69.418,-109.174,-129.339,-128.571,-103.587,-95.479,0,,0,,,,65,5.70,1
23,38.344,"Mount",72.512,-113.988,-135.059,-134.254,-108.112,-99.648,0,,0,,,,72,6.00,1
24,39.983,"Mount",75.450,-119.009,-140.876,-140.055,-112.782,-103.963,0,,0,,,,48,4.90,0
25,41.618,"Mount",78.633,-124.026,-146.816,-145.961,-117.562,-108.369,0,,0,,,,69,5.87,1
26,43.238,"Mount",82.685,-129.411,-153.520,-152.578,-122.851,-113.221,0,,0,,,,47,4.85,0
27,44.853,"Mount",84.913,-134.025,-158.622,-157.702,-127.228,-117.265,0,,0,,,,57,5.34,1
28,46.470,"Mount",88.165,-139.135,-164.677,-163.721,-132.018,-121.686,0,,0,,,,45,4.74,0
29,48.076,"Mount",91.387,-143.946,-170.461,-169.459,-136.723,-126.012,0,,0,,,,54,5.20,1
30,49.697,"Mount",94.469,-149.011,-176.390,-175.362,-141.502,-130.420,0,,0,,,,49,4.95,0
31,51.321,"Mount",96.972,-152.576,-180.736,-179.665,-145.288,-133.883,0,,0,,,,41,4.53,0
32,52.924,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
33,54.688,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
34,56.425,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
35,58.159,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
36,59.825,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
Guiding Ends at 2021-01-09 22:38:38
INFO: Guiding parameter change, MultiStar = falseGuiding Begins at 2021-01-09 22:39:41
Exposure = 1000 ms
Lock position = 188.725, 571.487, Star position = 188.725, 571.487, HFD = 5.61 px
1,1.783,"Mount",3.349,-5.899,-6.781,-6.771,-4.323,-4.062,0,,0,,,,68,5.83,1
2,3.417,"Mount",6.033,-11.003,-12.537,-12.534,-8.911,-8.333,0,,0,,,,66,5.74,1
3,5.055,"Mount",8.517,-16.033,-18.128,-18.145,-13.450,-12.553,0,,0,,,,66,5.74,0
4,6.698,"Mount",11.957,-20.958,-24.122,-24.080,-18.236,-16.959,0,,0,,,,85,6.52,1
5,8.353,"Mount",15.619,-26.315,-30.601,-30.502,-23.383,-21.693,0,,0,,,,93,6.82,0
6,10.000,"Mount",18.448,-32.564,-37.413,-37.358,-28.820,-26.753,0,,0,,,,52,5.10,0
7,11.651,"Mount",21.588,-35.581,-41.618,-41.447,-32.655,-30.219,0,,0,,,,64,5.66,1
8,13.308,"Mount",25.046,-39.859,-47.067,-46.810,-36.945,-34.130,0,,0,,,,70,5.92,1
9,14.960,"Mount",27.577,-44.976,-52.756,-52.518,-41.483,-38.337,0,,0,,,,86,6.56,0
10,16.614,"Mount",30.961,-49.830,-58.660,-58.366,-46.211,-42.687,0,,0,,,,70,5.92,1
11,18.249,"Mount",33.983,-55.499,-65.075,-64.785,-51.305,-47.408,0,,0,,,,89,6.67,1
12,19.883,"Mount",37.608,-59.800,-70.631,-70.242,-55.930,-51.627,0,,0,,,,96,6.93,1
13,21.524,"Mount",40.064,-66.009,-77.215,-76.898,-61.110,-56.464,0,,0,,,,71,5.96,1
14,23.155,"Mount",42.389,-70.487,-82.252,-81.943,-65.421,-60.459,0,,0,,,,70,5.92,1
15,24.808,"Mount",46.029,-75.657,-88.558,-88.186,-70.358,-65.003,0,,0,,,,65,5.70,1
16,26.448,"Mount",48.818,-80.599,-94.230,-93.851,-75.023,-69.311,0,,0,,,,81,6.36,1
17,28.085,"Mount",52.289,-85.859,-100.527,-100.101,-80.029,-73.923,0,,0,,,,70,5.92,1
18,29.712,"Mount",55.430,-91.149,-106.680,-106.233,-85.014,-78.525,0,,0,,,,71,5.96,1
19,31.345,"Mount",57.920,-96.264,-112.345,-111.922,-89.685,-82.858,0,,0,,,,76,6.16,1
20,32.955,"Mount",61.249,-100.737,-117.895,-117.403,-94.216,-87.013,0,,0,,,,76,6.16,1
21,34.569,"Mount",64.692,-105.006,-123.329,-122.750,-98.643,-91.053,0,,0,,,,108,7.35,0
22,36.183,"Mount",68.049,-109.197,-128.652,-127.990,-102.977,-95.004,0,,0,,,,62,5.57,1
23,37.801,"Mount",71.090,-113.987,-134.324,-133.629,-107.514,-99.178,0,,0,,,,54,5.20,1
24,39.421,"Mount",73.650,-118.849,-139.809,-139.121,-111.975,-103.308,0,,0,,,,72,6.00,1
25,41.034,"Mount",76.761,-123.902,-145.743,-145.027,-116.706,-107.678,0,,0,,,,70,5.92,1
26,42.649,"Mount",79.431,-128.760,-151.282,-150.564,-121.242,-111.874,0,,0,,,,77,6.20,1
27,44.272,"Mount",82.888,-133.541,-157.161,-156.378,-125.954,-116.201,0,,0,,,,75,6.12,1
28,45.895,"Mount",86.093,-139.269,-163.722,-162.932,-131.138,-120.999,0,,0,,,,55,5.24,0
29,47.518,"Mount",89.321,-144.026,-169.462,-168.623,-135.899,-125.373,0,,0,,,,65,5.70,1
30,49.138,"Mount",91.911,-147.742,-173.982,-173.099,-139.792,-128.934,0,,0,,,,55,5.24,0
31,50.779,"Mount",96.230,-155.070,-182.487,-181.579,-146.042,-134.734,0,,0,,,,67,5.79,1
32,52.421,"Mount",101.358,-156.196,-186.101,-184.843,-149.673,-137.853,0,,0,,,,48,4.90,0
33,54.080,"Mount",107.599,-158.685,-191.456,-189.820,-153.859,-141.463,0,,0,,,,71,5.96,1
34,55.706,"Mount",105.078,-167.930,-198.070,-197.019,-158.964,-146.504,0,,0,,,,61,5.52,0
35,57.316,"Mount",107.713,-172.844,-203.638,-202.590,-163.599,-150.855,0,,0,,,,73,6.04,1
36,58.933,"Mount",111.166,-176.887,-208.884,-207.740,-167.929,-154.815,0,,0,,,,55,5.24,1
37,60.544,"Mount",113.995,-181.181,-214.022,-212.839,-172.124,-158.667,0,,0,,,,75,6.12,1
38,62.155,"Mount",117.825,-185.921,-220.059,-218.780,-176.864,-163.001,0,,0,,,,60,5.48,1
39,63.771,"Mount",120.739,-190.095,-225.138,-223.810,-181.109,-166.886,0,,0,,,,56,5.29,0
40,65.382,"Mount",123.088,-195.019,-230.567,-229.265,-185.472,-170.936,0,,0,,,,64,5.66,1
41,66.995,"Mount",126.653,-199.379,-236.143,-234.749,-189.954,-175.036,0,,0,,,,37,4.30,0
42,68.605,"Mount",130.254,-203.892,-241.867,-240.384,-194.555,-179.238,0,,0,,,,47,4.85,1
43,70.224,"Mount",132.412,-209.387,-247.688,-246.269,-199.244,-183.609,0,,0,,,,80,6.32,1
44,71.848,"Mount",136.275,-214.127,-253.742,-252.224,-204.100,-188.056,0,,0,,,,50,5.00,0
45,73.487,"Mount",138.543,-219.077,-259.151,-257.667,-208.580,-192.211,0,,0,,,,56,5.29,0
46,75.122,"Mount",142.130,-224.439,-265.595,-264.060,-213.640,-196.878,0,,0,,,,62,5.57,1
47,76.765,"Mount",144.791,-229.455,-271.265,-269.735,-218.330,-201.217,0,,0,,,,62,5.57,0
48,78.389,"Mount",147.502,-233.669,-276.274,-274.712,-222.520,-205.070,0,,0,,,,44,4.69,1
49,80.028,"Mount",151.157,-238.946,-282.680,-281.058,-227.494,-209.649,0,,0,,,,85,6.52,1
50,81.693,"Mount",153.407,-243.487,-287.731,-286.126,-231.771,-213.605,0,,0,,,,68,5.83,0
51,83.306,"Mount",157.548,-248.360,-294.042,-292.322,-236.703,-218.114,0,,0,,,,55,5.24,1
52,84.922,"Mount",160.701,-253.025,-299.665,-297.897,-241.336,-222.361,0,,0,,,,54,5.20,0
53,86.546,"Mount",163.229,-257.795,-305.055,-303.293,-245.757,-226.448,0,,0,,,,65,5.70,1
54,88.169,"Mount",166.507,-262.545,-310.816,-309.001,-250.369,-230.690,0,,0,,,,69,5.87,1
55,89.790,"Mount",170.087,-267.444,-316.860,-314.974,-255.201,-235.122,0,,0,,,,69,5.87,1
56,91.414,"Mount",172.321,-271.872,-321.806,-319.933,-259.381,-238.985,0,,0,,,,65,5.70,1
57,93.031,"Mount",175.394,-276.352,-327.228,-325.308,-263.727,-242.981,0,,0,,,,59,5.43,1
58,94.654,"Mount",178.699,-281.609,-333.437,-331.482,-268.608,-247.486,0,,0,,,,66,5.74,1
59,96.281,"Mount",181.679,-286.834,-339.450,-337.485,-273.479,-251.988,0,,0,,,,52,5.10,1
60,97.914,"Mount",185.275,-291.726,-345.497,-343.459,-278.368,-256.473,0,,0,,,,42,4.58,0
61,99.535,"Mount",188.584,-296.651,-351.423,-349.338,-283.186,-260.897,0,,0,,,,55,5.24,0
62,101.154,"Mount",190.643,-301.370,-356.527,-354.481,-287.463,-264.868,0,,0,,,,68,5.83,0
63,102.783,"Mount",194.333,-305.603,-362.058,-359.905,-291.898,-268.916,0,,0,,,,52,5.10,1
64,104.403,"Mount",197.147,-310.445,-367.658,-365.491,-296.410,-273.078,0,,0,,,,47,4.85,0
65,106.025,"Mount",199.225,-315.637,-373.177,-371.068,-300.888,-277.257,0,,0,,,,60,5.48,1
66,107.650,"Mount",203.220,-320.556,-379.452,-377.242,-305.840,-281.797,0,,0,,,,73,6.04,1
67,109.259,"Mount",206.020,-325.232,-384.903,-382.673,-310.366,-285.963,0,,0,,,,47,4.85,1
68,110.869,"Mount",209.643,-329.723,-390.619,-388.298,-314.973,-290.171,0,,0,,,,68,5.83,0
69,112.482,"Mount",211.817,-334.894,-396.171,-393.899,-319.490,-294.374,0,,0,,,,59,5.43,1
70,114.103,"Mount",215.232,-339.259,-401.672,-399.320,-323.957,-298.467,0,,0,,,,70,5.92,1
71,115.721,"Mount",218.723,-344.108,-407.627,-405.210,-328.703,-302.820,0,,0,,,,58,5.39,1
72,117.339,"Mount",221.751,-348.646,-413.077,-410.617,-333.186,-306.934,0,,0,,,,63,5.61,1
73,118.961,"Mount",224.531,-353.270,-418.472,-415.992,-337.578,-310.982,0,,0,,,,78,6.24,1
74,120.578,"Mount",226.885,-358.048,-423.780,-421.319,-341.895,-314.988,0,,0,,,,41,4.53,1
75,122.199,"Mount",230.184,-363.260,-429.947,-427.450,-346.744,-319.468,0,,0,,,,66,5.74,0
76,123.820,"Mount",233.088,-367.378,-434.972,-432.425,-350.978,-323.348,0,,0,,,,64,5.66,1
77,125.441,"Mount",235.836,-372.851,-441.078,-438.549,-355.770,-327.799,0,,0,,,,66,5.74,1
78,127.058,"Mount",239.363,-377.017,-446.467,-443.841,-360.224,-331.864,0,,0,,,,34,4.12,0
79,128.677,"Mount",242.275,-382.021,-452.256,-449.615,-364.861,-336.142,0,,0,,,,45,4.74,0
80,130.300,"Mount",245.135,-387.347,-458.294,-455.656,-369.695,-340.622,0,,0,,,,57,5.34,0
81,131.909,"Mount",248.633,-392.204,-464.260,-461.556,-374.526,-345.058,0,,0,,,,67,5.79,1
82,133.521,"Mount",251.061,-396.940,-469.569,-466.877,-378.937,-349.138,0,,0,,,,42,4.58,0
83,135.172,"Mount",253.555,-402.034,-475.219,-472.549,-383.476,-353.357,0,,0,,,,75,6.12,0
84,136.823,"Mount",257.710,-406.600,-481.276,-478.476,-388.302,-357.757,0,,0,,,,62,5.57,1
85,138.467,"Mount",261.050,-411.175,-486.918,-484.053,-392.924,-361.983,0,,0,,,,80,6.32,1
86,140.116,"Mount",263.867,-416.769,-493.163,-490.316,-397.888,-366.586,0,,0,,,,71,5.96,0
87,141.757,"Mount",266.849,-421.190,-498.489,-495.597,-402.338,-370.676,0,,0,,,,47,4.85,1
88,143.392,"Mount",269.746,-426.187,-504.265,-501.360,-406.965,-374.951,0,,0,,,,70,5.92,0
89,145.031,"Mount",273.732,-430.140,-509.707,-506.661,-411.418,-378.987,0,,0,,,,46,4.80,0
90,146.689,"Mount",276.139,-435.510,-515.549,-512.543,-416.089,-383.323,0,,0,,,,44,4.69,1
91,148.349,"Mount",279.177,-440.605,-521.481,-518.454,-420.863,-387.737,0,,0,,,,51,5.05,0
92,150.001,"Mount",282.384,-444.922,-526.834,-523.741,-425.290,-391.792,0,,0,,,,46,4.80,0
93,151.638,"Mount",284.875,-449.962,-532.437,-529.364,-429.803,-395.977,0,,0,,,,40,4.47,1
94,153.272,"Mount",288.291,-455.456,-538.905,-535.799,-434.885,-400.675,0,,0,,,,63,5.61,1
95,154.909,"Mount",291.510,-459.899,-544.373,-541.205,-439.451,-404.858,0,,0,,,,51,5.05,0
96,156.552,"Mount",294.537,-464.607,-549.967,-546.763,-443.987,-409.030,0,,0,,,,42,4.58,1
97,158.194,"Mount",298.426,-469.761,-556.389,-553.103,-449.046,-413.667,0,,0,,,,73,6.04,0
98,159.846,"Mount",301.230,-474.397,-561.807,-558.498,-453.574,-417.832,0,,0,,,,66,5.74,0
116,196.345,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
117,198.097,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
118,199.862,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
INFO: GA Result - SNR=5.6, Samples=98, Elapsed Time=158s, RA HPF-RMS= 0.29 px ( 1.11 Bogensek ), Dec HPF-RMS= 0.30 px ( 1.17 Bogensek ), Total HPF-RMS= 0.42 px ( 1.61 Bogensek )
INFO: GA Result - RA Peak= 8.51 px ( 32.89 Bogensek ), RA Peak-Peak 520.44 px (2012.80 Bogensek ), RA Drift Rate=-210.77 px/min (-815.14 Bogensek/min ), Max RA Drift Rate= 3.65 px/s ( 14.12 Bogensek/s ), Drift-Limiting Exp= 0.0 s
INFO: GA Result - Dec Drift Rate=-208.88 px/min (-807.82 Bogensek/min ), Dec Peak= 8.48 px ( 32.80 Bogensek ), PA Error=> 3085.6 Bogenmin
INFO: GA Result - Recommendation: Du solltest die Kalibrierung wiederholen(Vor-Alarm)
INFO: GA Result - Recommendation: Fehler der Polausrichtung > 10 Bogenmin; versuche mit dem Justage Tool die Ausrichtung zu verbessern.
INFO: GA Result - Recommendation: versuche die RA Min-Bewegung auf 0.12 zu setzen
INFO: GA Result - Recommendation: versuche die DEC Min-Bewegung auf 0.19 zu setzen
119,201.616,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
120,203.357,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
121,205.112,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
122,206.848,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
123,208.590,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
124,210.334,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
125,212.107,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
INFO: Guiding parameter change, RA Hysteresis MinMove = 0.12
INFO: Guiding parameter change, Declination Hysteresis MinMove = 0.19
126,213.930,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
127,215.728,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
128,217.476,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
129,219.234,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
130,220.983,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
131,222.724,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
132,224.464,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
133,226.192,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
134,227.928,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
135,229.668,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
Guiding Ends at 2021-01-09 22:43:31Guiding Begins at 2021-01-09 22:43:38
Exposure = 1000 ms
X guide algorithm = Hysteresis, Hysteresis = 0.250, Aggression = 0.850, Minimum move = 0.124
Y guide algorithm = Hysteresis, Hysteresis = 0.250, Aggression = 0.800, Minimum move = 0.192
Lock position = 360.591, 522.829, Star position = 360.591, 522.829, HFD = 5.71 px
1,1.926,"Mount",3.118,-5.436,-6.265,-6.253,-3.994,-3.752,147,E,0,,,,277,11.51,0
2,3.884,"Mount",6.654,-10.688,-12.589,-12.525,-8.874,-8.265,326,E,0,,,,177,9.24,0
3,6.012,"Mount",9.994,-16.203,-19.036,-18.946,-14.021,-13.021,516,E,0,,,,249,10.95,0
4,8.357,"Mount",13.907,-22.872,-26.768,-26.656,-20.044,-18.598,737,E,0,,,,256,11.10,0
5,10.935,"Mount",18.077,-29.609,-34.691,-34.540,-26.375,-24.444,970,E,0,,,,258,11.13,0
6,13.747,"Mount",22.361,-36.125,-42.483,-42.276,-32.688,-30.254,1203,E,0,,,,235,10.63,0
7,16.801,"Mount",26.588,-43.177,-50.704,-50.467,-39.270,-36.331,1445,E,0,,,,253,11.00,0
8,20.095,"Mount",30.979,-50.199,-58.985,-58.705,-45.948,-42.489,1690,E,0,,,,233,10.60,0
9,23.788,"Mount",37.292,-58.837,-69.643,-69.238,-54.161,-50.040,1993,E,0,,,,207,10.00,0
10,27.657,"Mount",41.356,-66.170,-78.021,-77.610,-61.248,-56.574,2253,E,0,,,,290,11.78,1
11,31.761,"Mount",47.291,-75.378,-88.971,-88.490,-69.734,-64.409,2500,E,0,,,,227,10.42,0
12,35.872,"Mount",52.167,-83.944,-98.825,-98.327,-77.819,-71.878,2500,E,0,,,,203,9.88,1
13,39.986,"Mount",57.084,-92.542,-108.726,-108.211,-85.850,-79.302,2500,E,0,,,,228,10.45,1
14,44.099,"Mount",63.336,-100.981,-119.182,-118.538,-94.221,-86.983,2500,E,0,,,,186,9.49,0
15,48.228,"Mount",67.598,-109.684,-128.836,-128.230,-102.155,-94.334,2500,E,0,,,,211,10.07,0
Guiding Ends at 2021-01-09 22:44:27Guiding Begins at 2021-01-09 22:44:34
Exposure = 1000 ms
Max RA duration = 2500, Max DEC duration = 2500, DEC guide mode = Off
Lock position = 446.086, 384.975, Star position = 446.086, 384.975, HFD = 6.20 px
1,1.930,"Mount",3.208,-5.087,-6.013,-5.979,-3.833,-3.587,141,E,0,,,,237,10.66,0
2,3.870,"Mount",6.461,-10.284,-12.143,-12.077,-8.556,-7.964,315,E,0,,,,226,10.40,0
3,5.989,"Mount",9.594,-15.525,-18.249,-18.161,-13.452,-12.490,495,E,0,,,,207,9.95,1
4,8.300,"Mount",13.238,-20.835,-24.678,-24.532,-18.591,-17.217,684,E,0,,,,230,10.47,0
5,10.803,"Mount",16.704,-27.057,-31.796,-31.645,-24.221,-22.430,891,E,0,,,,219,10.23,1
6,13.530,"Mount",20.613,-32.834,-38.762,-38.551,-29.858,-27.617,1098,E,0,,,,271,11.37,1
7,16.484,"Mount",24.416,-39.403,-46.351,-46.123,-35.894,-33.197,1321,E,0,,,,221,10.28,0
8,19.667,"Mount",28.844,-45.930,-54.228,-53.932,-42.198,-38.999,1552,E,0,,,,244,10.82,1
9,23.104,"Mount",33.003,-53.138,-62.547,-62.234,-48.841,-45.140,1797,E,0,,,,205,9.93,1
10,26.788,"Mount",37.463,-60.828,-71.436,-71.101,-55.919,-51.689,2057,E,0,,,,187,9.43,0
11,30.745,"Mount",42.809,-68.617,-80.867,-80.447,-63.435,-58.606,2334,E,0,,,,213,10.10,0
12,34.870,"Mount",47.764,-77.073,-90.667,-90.220,-71.280,-65.853,2500,E,0,,,,164,8.88,0
13,39.006,"Mount",53.389,-86.013,-101.228,-100.723,-79.680,-73.604,2500,E,0,,,,194,9.63,1
14,43.131,"Mount",58.853,-94.895,-111.655,-111.102,-88.112,-81.382,2500,E,0,,,,207,9.95,0
15,47.255,"Mount",64.037,-103.318,-121.545,-120.946,-96.209,-88.844,2500,E,0,,,,191,9.54,1
16,51.407,"Mount",69.431,-111.799,-131.593,-130.934,-104.335,-96.329,2500,E,0,,,,234,10.58,1
17,55.536,"Mount",74.440,-120.779,-141.870,-141.201,-112.613,-103.987,2500,E,0,,,,221,10.25,1
18,59.676,"Mount",79.503,-129.353,-151.827,-151.129,-120.720,-111.474,2500,E,0,,,,158,8.72,1
19,63.807,"Mount",84.774,-137.871,-161.843,-161.096,-128.828,-118.953,2500,E,0,,,,200,9.76,1
20,67.960,"Mount",90.391,-146.044,-171.743,-170.906,-136.862,-126.334,2500,E,0,,,,183,9.29,0
21,72.087,"Mount",94.663,-155.011,-181.628,-180.838,-144.871,-133.769,2500,E,0,,,,200,9.77,1
22,76.216,"Mount",100.220,-163.510,-191.775,-190.914,-153.042,-141.302,2500,E,0,,,,176,9.19,1
23,80.354,"Mount",105.670,-172.379,-202.185,-201.276,-161.414,-149.026,2500,E,0,,,,206,9.91,1
24,84.487,"Mount",111.193,-181.233,-212.619,-211.655,-169.845,-156.798,2500,E,0,,,,177,9.24,0
25,88.614,"Mount",116.741,-189.579,-222.631,-221.590,-178.019,-164.313,2500,E,0,,,,190,9.51,1
26,92.755,"Mount",121.526,-198.228,-232.508,-231.462,-186.053,-171.740,2500,E,0,,,,204,9.88,0
27,96.896,"Mount",126.775,-206.900,-242.645,-241.558,-194.223,-179.283,2500,E,0,,,,183,9.36,0
28,101.044,"Mount",132.272,-215.329,-252.702,-251.545,-202.370,-186.783,2500,E,0,,,,168,8.99,1
29,105.167,"Mount",137.006,-223.725,-262.337,-261.168,-210.243,-194.057,2500,E,0,,,,195,9.62,0
30,109.295,"Mount",142.549,-234.645,-274.551,-273.413,-219.703,-202.859,2500,E,0,,,,189,9.47,0
31,113.420,"Mount",148.476,-244.351,-285.922,-284.735,-228.962,-211.413,2500,E,0,,,,212,10.07,1
32,117.542,"Mount",153.439,-249.725,-293.088,-291.743,-235.498,-217.328,2500,E,0,,,,183,9.36,0
33,121.666,"Mount",158.693,-258.225,-303.080,-301.687,-243.257,-224.478,2500,E,0,,,,178,9.24,0
34,125.809,"Mount",164.422,-266.724,-313.316,-311.838,-251.431,-231.999,2500,E,0,,,,167,8.92,0
35,129.935,"Mount",169.483,-275.778,-323.683,-322.195,-259.777,-239.717,2500,E,0,,,,179,9.26,1
36,134.049,"Mount",174.582,-284.808,-334.050,-332.548,-268.159,-247.472,2500,E,0,,,,193,9.57,0
37,138.162,"Mount",179.463,-293.466,-343.985,-342.470,-276.274,-254.976,2500,E,0,,,,187,9.43,0
38,142.294,"Mount",184.410,-302.201,-354.018,-352.489,-284.395,-262.489,2500,E,0,,,,191,9.55,1
39,146.477,"Mount",190.975,-310.298,-364.343,-362.648,-292.703,-270.086,2500,E,0,,,,182,9.32,0
40,150.600,"Mount",196.380,-319.054,-374.632,-372.888,-301.027,-277.750,2500,E,0,,,,161,8.82,0
41,154.716,"Mount",201.413,-327.503,-384.467,-382.689,-309.066,-285.164,2500,E,0,,,,171,9.04,0
42,158.856,"Mount",206.531,-335.979,-394.368,-392.552,-317.086,-292.564,2500,E,0,,,,165,8.88,1
43,162.978,"Mount",211.559,-344.162,-403.972,-402.112,-324.913,-299.780,2500,E,0,,,,190,9.53,0
44,164.596,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
45,166.383,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
46,168.151,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
47,169.923,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
48,171.717,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
49,173.506,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
50,175.285,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
51,177.047,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
52,178.841,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
53,180.614,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
54,182.405,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
55,184.184,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
56,185.949,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
Guiding Ends at 2021-01-09 22:47:41Log Summary: calcnt:8 gcnt:20 gdur:1343 gacnt:1
Log closed at 2021-01-09 22:47:44
PHD2 version 2.6.9dev2 [Windows], Log version 2.5. Log enabled at 2021-01-09 21:54:08
INFO: Guiding parameter change, MultiStar = falseGuiding Begins at 2021-01-09 22:48:05
Exposure = 1000 ms
Lock position = 379.305, 178.763, Star position = 379.305, 178.763, HFD = 4.45 px
Guiding Ends at 2021-01-09 22:48:07
INFO: Guiding parameter change, MultiStar = falseCalibration Begins at 2021-01-09 22:48:12
Exposure = 1000 ms
Mount = On Camera, Calibration Step = 250 ms, Calibration Distance = 25 px, Assume orthogonal axes = no
Direction,Step,dx,dy,x,y,Dist
West,0,0.000,0.000,378.054,177.365,0.000
West,1,0.381,-0.656,377.673,178.020,0.758
West,2,1.164,-1.471,376.890,178.836,1.875
West,3,2.040,-1.608,376.014,178.973,2.598
West,4,2.441,-1.662,375.613,179.027,2.953
West,5,2.211,-2.008,375.843,179.373,2.986
West,6,2.811,-1.664,375.243,179.029,3.267
INFO: STAR LOST during calibration, Mass= 0, SNR= 0.00, Error= 3, Status=Stern verloren - geringe Größe
INFO: STAR LOST during calibration, Mass= 0, SNR= 0.00, Error= 2, Status=Stern verloren - geringes SNR
Guiding Ends at 2021-01-09 22:48:36
INFO: Guiding parameter change, MultiStar = falseCalibration Begins at 2021-01-09 22:48:40
Exposure = 1000 ms
Lock position = 348.372, 637.284, Star position = 348.372, 637.284, HFD = 4.76 px
West,0,0.000,0.000,347.149,636.840,0.000
West,1,0.444,-0.782,346.705,637.622,0.899
West,2,1.078,-0.904,346.071,637.743,1.407
West,3,1.005,0.268,346.144,636.571,1.040
West,4,-20.867,-8.075,368.016,644.915,22.375
West,5,-16.433,-8.623,363.583,645.463,18.558
West,6,-15.501,-8.677,362.651,645.517,17.765
West,7,-16.184,-9.439,363.334,646.278,18.735
West,8,-12.885,-9.258,360.034,646.097,15.866
West,9,-11.162,-9.068,358.311,645.908,14.381
West,10,-11.556,-9.538,358.705,646.378,14.984
West,11,-9.954,-8.785,357.104,645.625,13.276
West,12,-8.671,-8.499,355.821,645.338,12.142
West,13,-9.239,-9.316,356.389,646.156,13.121
West,14,-10.477,-10.643,357.626,647.483,14.934
West,15,-7.203,-9.825,354.353,646.665,12.183
West,16,-11.080,-11.906,358.230,648.746,16.265
West,17,-9.395,-11.489,356.545,648.329,14.842
West,18,-5.982,-10.604,353.132,647.443,12.175
West,19,-7.604,-11.297,354.753,648.137,13.618
West,20,-8.912,-12.748,356.062,649.587,15.554
West,21,-6.734,-12.732,353.884,649.572,14.403
West,22,-3.607,-11.994,350.756,648.834,12.525
West,23,10.856,-4.897,336.294,641.737,11.909
West,24,-1.643,-4.763,348.793,641.603,5.038
West,25,13.083,-1.781,334.066,638.620,13.204
West,26,10.006,-4.486,337.144,641.326,10.965
West,27,10.680,-6.134,336.470,642.974,12.316
West,28,11.270,-4.492,335.879,641.332,12.133
West,29,11.278,-3.588,335.872,640.428,11.835
West,30,11.532,-3.678,335.618,640.517,12.104
West,31,12.642,-4.149,334.507,640.988,13.306
West,32,13.582,-4.860,333.567,641.700,14.425
West,33,13.488,-5.185,333.662,642.024,14.450
West,34,14.507,-5.137,332.643,641.976,15.389
West,35,14.450,-4.704,332.699,641.544,15.196
West,36,14.875,-5.831,332.274,642.671,15.977
West,37,15.754,-5.592,331.396,642.432,16.717
West,38,16.541,-6.024,330.608,642.864,17.604
West,39,17.084,-6.157,330.065,642.997,18.160
West,40,17.474,-6.425,329.676,643.264,18.618
West,41,17.346,-6.742,329.804,643.581,18.610
West,42,17.912,-6.613,329.237,643.452,19.094
West,43,19.072,-6.303,328.077,643.143,20.087
West,44,18.727,-6.420,328.423,643.259,19.797
West,45,19.975,-7.064,327.175,643.904,21.187
West,46,19.791,-7.505,327.358,644.345,21.167
West,47,20.492,-7.322,326.658,644.161,21.761
West,48,20.239,-7.385,326.911,644.225,21.544
West,49,20.298,-6.983,326.852,643.822,21.465
West,50,21.546,-6.029,325.603,642.869,22.374
West,51,21.572,-6.416,325.578,643.256,22.506
West,52,23.473,-7.704,323.676,644.544,24.705
West,53,25.398,-9.973,321.752,646.813,27.286
West calibration complete. Angle = -21.4 deg, Rate = 2.059 px/sec, Parity = N/A
East,6,25.398,-9.973,321.752,646.813,27.286
East,5,23.029,-6.629,324.121,643.468,23.964
Guiding Ends at 2021-01-09 22:50:34
INFO: Guiding parameter change, MultiStar = falseCalibration Begins at 2021-01-09 22:50:57
Exposure = 1000 ms
Lock position = 336.557, 851.068, Star position = 336.557, 851.068, HFD = 5.54 px
West,0,0.000,0.000,333.794,848.225,0.000
West,1,0.592,0.278,333.202,847.947,0.654
West,2,2.461,0.215,331.333,848.010,2.470
West,3,2.631,0.447,331.163,847.779,2.668
West,4,3.391,0.041,330.404,848.184,3.391
West,5,4.422,-0.322,329.372,848.547,4.434
West,6,5.204,-0.603,328.590,848.829,5.238
West,7,6.322,-0.939,327.473,849.165,6.391
West,8,7.358,-0.375,326.436,848.600,7.367
West,9,7.566,-0.651,326.229,848.876,7.593
West,10,8.658,-0.736,325.136,848.961,8.689
West,11,9.340,-0.849,324.454,849.074,9.379
West,12,10.087,-2.643,323.707,850.869,10.428
West,13,11.134,-2.915,322.660,851.140,11.509
West,14,11.662,-2.744,322.132,850.969,11.981
West,15,12.148,-2.507,321.647,850.733,12.404
West,16,12.994,-2.902,320.800,851.127,13.314
West,17,13.388,-2.775,320.406,851.000,13.672
West,18,14.486,-3.466,319.308,851.692,14.895
West,19,15.064,-3.875,318.730,852.100,15.554
West,20,16.104,-4.387,317.690,852.612,16.691
West,21,16.745,-3.402,317.049,851.627,17.087
West,22,16.983,-3.558,316.811,851.783,17.352
West,23,17.840,-3.921,315.954,852.147,18.266
West,24,18.555,-3.586,315.239,851.812,18.898
West,25,19.367,-4.279,314.427,852.504,19.834
West,26,20.596,-4.605,313.198,852.830,21.104
West,27,21.355,-4.731,312.439,852.957,21.873
West,28,22.110,-4.390,311.684,852.615,22.542
West,29,22.589,-4.856,311.205,853.082,23.105
West,30,23.130,-5.847,310.664,854.072,23.858
West,31,24.125,-5.605,309.669,853.831,24.767
West,32,24.508,-6.251,309.286,854.476,25.293
West calibration complete. Angle = -14.3 deg, Rate = 3.162 px/sec, Parity = N/A
East,4,24.508,-6.251,309.286,854.476,25.293
East,3,22.952,-2.292,310.842,850.518,23.067
East,2,21.216,2.518,312.579,845.707,21.364
East,1,18.685,6.430,315.109,841.795,19.760
East,0,19.127,7.817,314.667,840.408,20.663
Backlash,0,0.000,0.000,314.667,840.408,0.000
Backlash,1,0.278,-0.314,314.389,840.722,0.419
Backlash,2,0.449,-0.375,314.217,840.783,0.585
Backlash,3,1.395,-0.236,313.272,840.644,1.415
Backlash,4,0.903,-0.675,313.763,841.083,1.128
Backlash,5,1.238,-0.073,313.429,840.481,1.240
Backlash,6,0.914,0.318,313.752,840.090,0.968
Backlash,7,0.811,0.651,313.856,839.757,1.040
Backlash,8,1.047,0.048,313.620,840.360,1.048
Backlash,9,1.531,-0.331,313.136,840.739,1.566
Backlash,10,1.731,-0.470,312.935,840.878,1.794
Backlash,11,1.898,-0.141,312.769,840.549,1.903
Backlash,12,1.652,-0.490,313.014,840.898,1.723
Backlash,13,1.746,-1.902,312.921,842.311,2.582
Backlash,14,3.140,-0.697,311.526,841.105,3.217
Backlash,15,3.160,-0.159,311.506,840.567,3.164
Backlash,16,2.772,-0.013,311.895,840.421,2.772
Backlash,17,-2.756,8.793,317.423,831.615,9.215
Backlash,18,-1.807,8.776,316.474,831.632,8.961
Backlash,19,-1.860,8.461,316.526,831.947,8.663
Guiding Ends at 2021-01-09 22:53:13 -
INFO: Guiding parameter change, MultiStar = true
INFO: Guiding parameter change, MultiStar = falseCalibration Begins at 2021-01-09 21:55:21
Exposure = 1000 ms
Lock position = 937.700, 441.850, Star position = 941.139, 436.889, HFD = 6.52 px
West,0,0.000,0.000,944.465,432.408,0.000
West,1,-3.869,5.658,948.333,426.750,6.854
West,2,-7.869,11.214,952.333,421.194,13.699
West,3,-11.793,16.634,956.258,415.774,20.391
West,4,-15.497,21.673,959.962,410.736,26.643
West calibration complete. Angle = 125.6 deg, Rate = 26.643 px/sec, Parity = N/A
East,2,-15.497,21.673,959.962,410.736,26.643
East,1,-20.935,28.133,965.400,404.275,35.068
East,0,-25.099,34.136,969.564,398.273,42.370
Backlash,0,0.000,0.000,969.564,398.273,0.000
Backlash,1,-4.076,6.273,973.640,392.000,7.481
Backlash,2,-7.873,10.909,977.436,387.364,13.453
Backlash,3,-12.386,16.348,981.950,381.925,20.510
North,0,0.000,0.000,977.436,387.364,0.000
North,1,-4.514,5.439,981.950,381.925,7.068
North,2,-7.628,10.864,985.065,376.500,13.274
North,3,-12.079,15.832,989.516,371.531,19.914
North,4,-15.793,20.921,993.230,366.443,26.213
North calibration complete. Angle = -53.0 deg, Rate = 26.213 px/sec, Parity = N/A
South,2,-15.793,20.921,993.230,366.443,26.213
South,1,-20.183,27.223,997.620,360.141,33.889
South,0,-24.987,32.979,1002.423,354.385,41.376
Calibration complete, mount = On Camera.Guiding Begins at 2021-01-09 21:55:49
Exposure = 1000 ms
Mount = On Camera, connected, guiding enabled, xAngle = 125.6, xRate = 26.643, yAngle = -53.0, yRate = 26.213, parity = ?/?
Norm rates RA = 103.0"/s (==>) dec 0, Dec = 101.4"/s; ortho.err. = 88.5 deg
Backlash comp = disabled, pulse = 20 ms
RA Guide Speed = Unknown, Dec Guide Speed = Unknown, Cal Dec = Unknown, Last Cal Issue = Orthogonality, Timestamp = 09.01.2021 21:55:49
Lock position = 1002.423, 354.385, Star position = 1002.423, 354.385, HFD = 5.30 px
1,2.120,"Mount",4.808,-6.077,-7.740,-7.727,-4.934,-4.636,185,E,177,N,,,52,5.10,0
2,4.460,"Mount",8.608,-11.353,-14.242,-14.227,-10.128,-9.464,380,E,361,N,,,64,5.66,1
3,7.284,"Mount",13.218,-18.573,-22.797,-22.790,-16.685,-15.567,626,E,594,N,,,53,5.15,0
4,10.664,"Mount",19.504,-26.276,-32.718,-32.692,-24.403,-22.729,916,E,867,N,,,55,5.24,1
5,14.740,"Mount",26.910,-36.090,-45.009,-44.971,-33.879,-31.528,1272,E,1203,N,,,78,6.24,1
6,19.630,"Mount",36.952,-46.869,-59.618,-59.526,-45.206,-42.021,1697,E,1603,N,,,64,5.66,0
7,25.498,"Mount",49.939,-58.471,-76.610,-76.413,-58.445,-54.252,2194,E,2070,N,,,58,5.39,0
8,32.113,"Mount",64.853,-73.793,-97.748,-97.461,-74.734,-69.327,2500,E,2500,N,,,76,6.16,1
9,38.738,"Mount",82.799,-89.848,-121.246,-120.815,-93.175,-86.355,2500,E,2500,N,,,54,5.20,0
10,45.354,"Mount",100.166,-106.015,-144.498,-143.938,-111.917,-103.634,2500,E,2500,N,,,73,6.04,1
11,51.975,"Mount",117.250,-123.185,-168.402,-167.732,-131.139,-121.366,2500,E,2500,N,,,55,5.24,1
12,58.597,"Mount",134.968,-139.822,-192.241,-191.441,-150.421,-139.138,2500,E,2500,N,,,64,5.66,1
13,65.213,"Mount",152.489,-155.502,-215.187,-214.247,-169.146,-156.376,2500,E,2500,N,,,68,5.83,1
14,71.822,"Mount",168.808,-170.218,-236.649,-235.580,-186.808,-172.623,2500,E,2500,N,,,78,6.24,1
15,78.432,"Mount",184.548,-184.270,-257.236,-256.040,-203.684,-188.149,2500,E,2500,N,,,70,5.92,1
16,83.154,"Mount",199.562,-197.597,-276.809,-275.491,-219.749,-202.924,2500,E,0,,,,66,5.74,1Log Summary: calcnt:1 gcnt:0 gdur:0 gacnt:0
Log closed at 2021-01-09 21:57:13
INFO: Guiding parameter change, MultiStar = falseGuiding Begins at 2021-01-09 21:57:33
Exposure = 1000 ms
Lock position = 518.289, 488.911, Star position = 518.289, 488.911, HFD = 6.69 px
1,2.083,"Mount",4.033,-5.543,-6.855,-6.851,-4.370,-4.111,164,E,157,N,,,87,6.60,0
Guiding Ends at 2021-01-09 21:57:36
INFO: Guiding parameter change, MultiStar = falseCalibration Begins at 2021-01-09 21:57:44
Exposure = 1000 ms
Lock position = 522.322, 483.368, Star position = 522.322, 483.368, HFD = 6.72 px
Guiding Ends at 2021-01-09 21:57:56
INFO: Guiding parameter change, MultiStar = falseCalibration Begins at 2021-01-09 21:58:00
Exposure = 1000 ms
Lock position = 183.839, 349.667, Star position = 183.839, 349.667, HFD = 6.97 px
West,0,0.000,0.000,200.000,330.272,0.000
West,1,-3.029,4.625,203.029,325.647,5.529
West,2,-5.794,9.085,205.794,321.187,10.776
West,3,-9.413,13.858,209.413,316.413,16.753
West,4,-12.669,17.247,212.669,313.025,21.400
West,5,-14.982,22.219,214.982,308.053,26.798
West calibration complete. Angle = 124.0 deg, Rate = 21.439 px/sec, Parity = N/A
East,2,-14.982,22.219,214.982,308.053,26.798
East,1,-19.733,27.939,219.733,302.333,34.205
East,0,-23.447,32.817,223.447,297.455,40.332
Backlash,0,0.000,0.000,223.447,297.455,0.000
Backlash,1,-4.398,6.073,227.846,291.382,7.499
Backlash,2,-8.812,10.732,232.259,286.723,13.886
Backlash,3,-12.340,15.205,235.787,282.250,19.582
North,0,0.000,0.000,232.259,286.723,0.000
North,1,-3.528,4.473,235.787,282.250,5.697
North,2,-9.291,10.386,241.550,276.337,13.935
North,3,-13.278,14.825,245.537,271.898,19.902
North,4,-17.067,19.923,249.326,266.800,26.234
North calibration complete. Angle = -49.4 deg, Rate = 26.234 px/sec, Parity = N/A
South,2,-17.067,19.923,249.326,266.800,26.234
South,1,-21.917,26.635,254.175,260.088,34.493
South,0,-25.536,32.339,257.795,254.385,41.205
Calibration complete, mount = On Camera.Guiding Begins at 2021-01-09 21:58:31
Exposure = 1000 ms
Mount = On Camera, connected, guiding enabled, xAngle = 124.0, xRate = 21.439, yAngle = -49.4, yRate = 26.234, parity = ?/?
Norm rates RA = 82.9"/s (==>) dec 0, Dec = 101.5"/s; ortho.err. = 83.4 deg
RA Guide Speed = Unknown, Dec Guide Speed = Unknown, Cal Dec = Unknown, Last Cal Issue = Orthogonality, Timestamp = 09.01.2021 21:58:31
Lock position = 257.795, 254.385, Star position = 257.795, 254.385, HFD = 7.63 px
1,2.110,"Mount",3.828,-5.201,-6.452,-6.379,-4.113,-3.827,192,E,146,N,,,98,7.00,1
2,4.463,"Mount",7.438,-10.451,-12.824,-12.702,-9.049,-8.387,422,E,320,N,,,90,6.71,1
Guiding Ends at 2021-01-09 21:58:37Guiding Begins at 2021-01-09 21:58:44
Exposure = 1000 ms
Lock position = 283.658, 218.458, Star position = 283.658, 218.458, HFD = 7.67 px
1,1.962,"Mount",4.419,-5.361,-6.916,-6.794,-4.409,-4.076,206,E,0,,,,103,7.18,1
2,3.978,"Mount",7.426,-10.281,-12.676,-12.545,-9.018,-8.342,421,E,0,,,,107,7.31,1
3,6.230,"Mount",11.086,-15.470,-19.024,-18.836,-14.044,-12.970,655,E,0,,,,86,6.56,1
4,8.748,"Mount",15.073,-21.069,-25.896,-25.642,-19.493,-17.979,909,E,0,,,,108,7.35,1
5,11.534,"Mount",19.861,-27.083,-33.559,-33.185,-25.536,-23.507,1191,E,0,,,,104,7.21,1
6,14.611,"Mount",24.041,-33.813,-41.476,-41.083,-31.867,-29.351,1486,E,0,,,,93,6.82,1
7,18.017,"Mount",28.722,-40.863,-49.938,-49.497,-38.607,-35.568,1801,E,0,,,,121,7.78,1
8,21.801,"Mount",35.955,-48.606,-60.402,-59.700,-46.710,-42.933,2179,E,0,,,,88,6.63,1
9,25.893,"Mount",40.002,-56.175,-68.940,-68.282,-53.875,-49.556,2500,E,0,,,,106,7.28,1
10,29.989,"Mount",46.140,-64.024,-78.879,-78.075,-61.734,-56.756,2500,E,0,,,,99,7.04,1
11,34.082,"Mount",51.934,-72.407,-89.069,-88.184,-69.900,-64.262,2500,E,0,,,,98,7.00,1
12,38.183,"Mount",57.876,-80.225,-98.873,-97.859,-77.885,-71.568,2500,E,0,,,,103,7.18,1
13,42.279,"Mount",63.524,-88.534,-108.920,-107.835,-85.987,-79.015,2500,E,0,,,,93,6.82,1
14,46.380,"Mount",69.099,-96.004,-118.230,-117.033,-93.644,-86.023,2500,E,0,,,,99,7.04,1
15,50.475,"Mount",76.372,-104.683,-129.492,-128.085,-102.451,-94.056,2500,E,0,,,,98,7.00,1
16,54.570,"Mount",82.121,-113.093,-139.679,-138.197,-110.816,-101.729,2500,E,0,,,,104,7.21,1
17,58.668,"Mount",88.314,-121.542,-150.146,-148.548,-119.267,-109.475,2500,E,0,,,,108,7.35,1
18,65.415,"Mount",94.167,-129.148,-159.725,-157.994,-127.169,-116.692,2500,E,2500,N,,,103,7.18,1
19,72.017,"Mount",109.149,-144.029,-180.439,-178.100,-142.053,-130.198,2500,E,2500,N,,,114,7.55,1
20,78.614,"Mount",124.360,-156.838,-199.564,-196.473,-157.408,-143.923,2500,E,2500,N,,,108,7.35,1
21,85.214,"Mount",139.066,-169.305,-218.122,-214.309,-172.502,-157.370,2500,E,2500,N,,,98,7.00,0
INFO: Guiding parameter change, Backlash comp enabled = true
22,91.812,"Mount",152.876,-181.765,-236.174,-231.726,-187.217,-170.510,2500,E,2500,N,,,88,6.63,0
23,98.416,"Mount",168.029,-194.650,-255.329,-250.139,-162.772,-150.083,2500,E,2500,N,,,99,7.04,1
Guiding Ends at 2021-01-09 22:00:22
INFO: Guiding parameter change, MultiStar = falseGuiding Begins at 2021-01-09 22:00:31
Exposure = 1000 ms
Lock position = 242.654, 888.240, Star position = 242.654, 888.240, HFD = 4.87 px
1,2.157,"Mount",4.088,-5.350,-6.721,-6.631,-4.285,-3.978,200,E,152,N,,,984,21.74,0
2,4.583,"Mount",11.340,-9.912,-14.558,-14.018,-10.191,-9.207,475,E,351,N,,,809,19.60,0
Guiding Ends at 2021-01-09 22:00:36
INFO: Guiding parameter change, MultiStar = falseCalibration Begins at 2021-01-09 22:00:48
Exposure = 1000 ms
Lock position = 253.994, 878.328, Star position = 253.994, 878.328, HFD = 5.85 px
Guiding Ends at 2021-01-09 22:00:54
INFO: Guiding parameter change, MultiStar = falseCalibration Begins at 2021-01-09 22:00:57
Exposure = 1000 ms
Lock position = 289.435, 825.704, Star position = 289.435, 825.704, HFD = 5.17 px
West,0,0.000,0.000,301.863,808.942,0.000
West,1,-4.918,4.460,306.781,804.482,6.639
West,2,-8.372,7.985,310.234,800.957,11.569
West,3,-10.912,13.170,312.775,795.771,17.104
West,4,-14.905,16.682,316.768,792.260,22.371
West,5,-17.925,20.816,319.788,788.126,27.470
West calibration complete. Angle = 130.7 deg, Rate = 21.976 px/sec, Parity = N/A
East,2,-17.925,20.816,319.788,788.126,27.470
East,1,-21.965,26.635,323.828,782.307,34.524
East,0,-25.329,32.166,327.191,776.776,40.941
Backlash,0,0.000,0.000,327.191,776.776,0.000
Backlash,1,-4.784,4.601,331.975,772.175,6.637
Backlash,2,-9.424,8.803,336.615,767.972,12.896
Backlash,3,-11.950,16.686,339.141,760.090,20.524
North,0,0.000,0.000,336.615,767.972,0.000
North,1,-2.526,7.883,339.141,760.090,8.278
North,2,-6.568,13.110,343.183,754.862,14.663
North,3,-10.699,18.007,347.314,749.966,20.945
North,4,-15.987,21.557,352.602,746.416,26.838
North calibration complete. Angle = -53.4 deg, Rate = 26.838 px/sec, Parity = N/A
South,2,-15.987,21.557,352.602,746.416,26.838
South,1,-32.863,27.319,369.478,740.653,42.735
South,0,-38.100,32.122,374.715,735.850,49.834
Calibration complete, mount = On Camera.Guiding Begins at 2021-01-09 22:01:28
Exposure = 1000 ms
Mount = On Camera, connected, guiding enabled, xAngle = 130.7, xRate = 21.976, yAngle = -53.4, yRate = 26.838, parity = ?/?
Norm rates RA = 85.0"/s (==>) dec 0, Dec = 103.8"/s; ortho.err. = 85.8 deg
RA Guide Speed = Unknown, Dec Guide Speed = Unknown, Cal Dec = Unknown, Last Cal Issue = Orthogonality, Timestamp = 09.01.2021 22:01:28
Lock position = 374.715, 735.850, Star position = 374.715, 735.850, HFD = 5.76 px
1,1.987,"Mount",0.018,-5.284,-4.015,-3.755,-2.560,-2.253,116,E,84,N,,,947,21.27,0
2,4.163,"Mount",3.892,-10.525,-10.515,-10.202,-7.247,-6.572,330,E,245,N,,,926,20.91,0
3,6.804,"Mount",8.291,-16.334,-17.788,-17.423,-12.880,-11.768,586,E,438,N,,,798,19.49,0
4,9.942,"Mount",12.765,-23.435,-26.087,-25.610,-19.368,-17.719,881,E,660,N,,,829,19.84,0
5,13.678,"Mount",19.052,-30.495,-35.540,-35.048,-26.772,-24.573,1218,E,916,N,,,825,19.79,0
6,18.150,"Mount",26.876,-39.107,-47.171,-46.672,-35.761,-32.918,1627,E,1227,N,,,879,20.41,0
7,23.441,"Mount",36.315,-48.579,-60.508,-60.043,-46.173,-42.610,2101,E,1588,N,,,880,20.47,0
8,29.549,"Mount",47.703,-59.286,-76.053,-75.667,-58.295,-53.922,2500,E,2009,N,,,768,19.19,0
9,36.145,"Mount",61.492,-71.557,-94.348,-94.092,-72.535,-67.239,2500,E,2500,N,,,731,18.74,0
10,42.752,"Mount",75.899,-83.826,-113.047,-112.952,-87.481,-81.219,2500,E,2500,N,,,770,19.15,0
11,49.358,"Mount",91.049,-97.043,-132.948,-133.009,-103.344,-96.049,2500,E,2500,N,,,694,18.17,0
12,55.957,"Mount",105.607,-109.759,-152.083,-152.291,-118.913,-110.584,2500,E,2500,N,,,685,18.12,0
13,62.535,"Mount",119.831,-122.270,-170.845,-171.194,-134.183,-124.833,2500,E,2500,N,,,801,19.49,0
14,69.119,"Mount",135.059,-134.945,-190.386,-190.921,-149.885,-139.519,2500,E,2500,N,,,780,19.28,0
15,75.706,"Mount",150.192,-147.859,-210.047,-210.751,-165.755,-154.354,2500,E,2500,N,,,691,18.18,0
16,82.329,"Mount",164.995,-161.219,-229.830,-230.663,-181.740,-169.269,2500,E,2500,N,,,791,19.46,0
Guiding Ends at 2021-01-09 22:02:50Guiding Begins at 2021-01-09 22:02:52
Exposure = 1000 ms
Lock position = 555.561, 561.547, Star position = 555.561, 561.547, HFD = 5.76 px
1,1.954,"Mount",3.747,-4.715,-6.018,-5.985,-3.836,-3.591,175,E,0,,,,690,18.04,0
2,3.937,"Mount",7.184,-9.744,-12.071,-11.973,-8.511,-7.902,387,E,0,,,,767,19.09,0
3,6.158,"Mount",11.017,-15.033,-18.580,-18.425,-13.653,-12.635,621,E,0,,,,826,19.95,0
4,8.648,"Mount",15.148,-20.568,-25.470,-25.261,-19.139,-17.684,871,E,0,,,,738,18.68,0
5,11.391,"Mount",19.392,-27.076,-33.171,-32.867,-25.214,-23.257,1147,E,0,,,,817,19.75,0
6,14.422,"Mount",24.251,-33.275,-41.039,-40.688,-31.520,-29.064,1434,E,0,,,,723,18.57,0
7,17.751,"Mount",29.156,-39.820,-49.199,-48.786,-38.062,-35.084,1732,E,0,,,,730,18.59,0
8,21.402,"Mount",34.215,-47.264,-58.141,-57.630,-45.153,-41.595,2055,E,0,,,,699,18.27,0
9,25.383,"Mount",39.279,-54.857,-67.199,-66.583,-52.435,-48.269,2386,E,0,,,,851,20.14,0
10,29.479,"Mount",45.923,-62.968,-77.680,-77.017,-60.664,-55.864,2500,E,0,,,,878,20.39,0
11,33.579,"Mount",52.101,-71.029,-87.821,-87.088,-68.877,-63.426,2500,E,0,,,,772,19.05,0
12,37.685,"Mount",57.888,-79.291,-97.858,-97.026,-77.021,-70.901,2500,E,0,,,,713,18.38,0
13,41.785,"Mount",63.829,-87.402,-107.880,-106.964,-85.140,-78.358,2500,E,0,,,,734,18.74,0
14,45.882,"Mount",69.999,-95.828,-118.291,-117.288,-93.503,-86.044,2500,E,0,,,,719,18.46,0
15,49.998,"Mount",75.910,-104.151,-128.455,-127.356,-101.760,-93.622,2500,E,0,,,,757,18.86,0
16,54.089,"Mount",82.351,-112.615,-139.072,-137.898,-110.282,-101.463,2500,E,0,,,,624,17.25,0
17,58.183,"Mount",88.173,-121.541,-149.634,-148.329,-118.827,-109.290,2500,E,0,,,,713,18.50,0
18,62.276,"Mount",94.963,-130.067,-160.526,-159.162,-127.586,-117.355,2500,E,0,,,,788,19.31,0
Guiding Ends at 2021-01-09 22:03:55Guiding Begins at 2021-01-09 22:04:11
Exposure = 1000 ms
Lock position = 686.697, 381.032, Star position = 686.697, 381.032, HFD = 5.80 px
1,1.947,"Mount",4.132,-5.008,-6.491,-6.464,-4.138,-3.879,188,E,0,,,,693,18.15,1
2,3.961,"Mount",7.595,-10.038,-12.562,-12.471,-8.888,-8.258,404,E,0,,,,660,17.71,0
3,6.191,"Mount",11.357,-15.280,-18.990,-18.840,-13.995,-12.956,637,E,0,,,,714,18.36,0
4,8.657,"Mount",15.074,-20.650,-25.484,-25.267,-19.220,-17.751,875,E,0,,,,698,18.23,0
5,11.402,"Mount",19.697,-26.937,-33.265,-32.984,-25.290,-23.340,1151,E,0,,,,678,18.00,0
6,14.434,"Mount",24.231,-33.207,-40.975,-40.626,-31.496,-29.043,1433,E,0,,,,767,19.08,0
7,17.759,"Mount",29.123,-39.810,-49.171,-48.756,-38.039,-35.062,1731,E,0,,,,710,18.38,0
8,21.400,"Mount",34.506,-46.812,-57.988,-57.515,-45.051,-41.521,2050,E,0,,,,767,19.12,0
9,25.388,"Mount",40.111,-54.519,-67.486,-66.930,-52.596,-48.462,2393,E,0,,,,754,18.95,0
10,29.484,"Mount",45.899,-62.492,-77.305,-76.664,-60.458,-55.691,2500,E,0,,,,745,18.79,0
11,33.597,"Mount",52.016,-70.646,-87.475,-86.757,-68.613,-63.192,2500,E,0,,,,824,19.69,0
Guiding Ends at 2021-01-09 22:04:44
INFO: Guiding parameter change, MultiStar = falseGuiding Begins at 2021-01-09 22:20:52
Exposure = 1000 ms
Lock position = 599.297, 539.608, Star position = 599.297, 539.608, HFD = 6.71 px
1,2.258,"Mount",4.450,-6.142,-7.558,-7.492,-4.818,-4.495,219,E,167,N,,,103,7.18,1
Guiding Ends at 2021-01-09 22:20:55
INFO: Guiding parameter change, MultiStar = falseCalibration Begins at 2021-01-09 22:21:01
Exposure = 1000 ms
Lock position = 603.748, 533.466, Star position = 603.748, 533.466, HFD = 7.56 px
West,0,0.000,0.000,617.624,509.366,0.000
West,1,-3.408,5.517,621.032,503.849,6.485
West,2,-7.799,11.109,625.423,498.258,13.573
West,3,-11.766,16.522,629.390,492.844,20.283
West,4,-14.134,21.806,631.758,487.560,25.986
West calibration complete. Angle = 123.0 deg, Rate = 25.986 px/sec, Parity = N/A
East,2,-14.134,21.806,631.758,487.560,25.986
East,1,-19.766,29.769,637.390,479.597,35.733
East,0,-22.249,37.099,639.873,472.268,43.259
Backlash,0,0.000,0.000,639.873,472.268,0.000
Backlash,1,-3.868,3.162,643.741,469.106,4.996
Backlash,2,-7.087,8.814,646.960,463.453,11.310
Backlash,3,-10.396,14.192,650.269,458.075,17.592
North,0,0.000,0.000,646.960,463.453,0.000
North,1,-3.309,5.378,650.269,458.075,6.314
North,2,-6.356,10.719,653.316,452.734,12.462
North,3,-10.200,16.747,657.160,446.707,19.608
North,4,-11.730,23.049,658.690,440.405,25.862
North calibration complete. Angle = -63.0 deg, Rate = 25.862 px/sec, Parity = N/A
South,2,-11.730,23.049,658.690,440.405,25.862
South,1,-17.992,29.610,664.952,433.843,34.648
South,0,-21.386,34.626,668.346,428.827,40.698
Calibration complete, mount = On Camera.Guiding Begins at 2021-01-09 22:21:30
Exposure = 1000 ms
Mount = On Camera, connected, guiding enabled, xAngle = 123.0, xRate = 25.986, yAngle = -63.0, yRate = 25.862, parity = ?/?
Norm rates RA = 100.5"/s (==>) dec 0, Dec = 100.0"/s; ortho.err. = 84.0 deg
RA Guide Speed = Unknown, Dec Guide Speed = Unknown, Cal Dec = Unknown, Last Cal Issue = Orthogonality, Timestamp = 09.01.2021 22:21:30
Lock position = 668.346, 428.827, Star position = 668.346, 428.827, HFD = 6.99 px
1,5.711,"Mount",10.494,-18.347,-21.104,-20.867,-13.454,-12.520,518,E,484,N,,,100,7.07,0
2,8.958,"Mount",15.396,-26.254,-30.405,-30.098,-22.242,-20.563,856,E,795,N,,,89,6.67,0
3,12.915,"Mount",21.620,-36.482,-42.373,-41.966,-31.739,-29.292,1221,E,1133,N,,,87,6.60,0
4,17.662,"Mount",28.779,-48.145,-56.054,-55.537,-42.479,-39.181,1635,E,1515,N,,,88,6.63,0
5,23.395,"Mount",37.849,-62.413,-72.960,-72.335,-55.539,-51.237,2137,E,1981,N,,,82,6.40,0
6,30.008,"Mount",48.900,-79.858,-93.610,-92.851,-71.478,-65.958,2500,E,2500,N,,,65,5.70,1
7,36.614,"Mount",61.788,-99.427,-117.041,-116.172,-89.802,-82.895,2500,E,2500,N,,,90,6.71,0
8,43.216,"Mount",73.257,-118.009,-138.871,-137.834,-107.614,-99.279,2500,E,2500,N,,,88,6.63,1
9,49.821,"Mount",85.347,-138.943,-163.014,-161.715,-126.789,-116.885,2500,E,2500,N,,,78,6.24,1
10,51.405,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
11,53.173,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
12,54.926,"DROP",,,,,,,,,,,,,0,0.00,2,"Stern verloren - geringes SNR"
Guiding Ends at 2021-01-09 22:22:26
INFO: Guiding parameter change, MultiStar = falseCalibration Begins at 2021-01-09 22:22:39
Exposure = 1000 ms
Lock position = 782.418, 230.088, Star position = 789.890, 220.012, HFD = 7.36 px
West,0,0.000,0.000,792.275,215.150,0.000
West,1,-3.667,6.069,795.942,209.081,7.090
West,2,-6.034,11.236,798.309,203.914,12.754
West,3,-10.093,15.834,802.368,199.316,18.778
West,4,-13.636,21.618,805.911,193.532,25.560
West calibration complete. Angle = 122.2 deg, Rate = 25.560 px/sec, Parity = N/A
East,2,-13.636,21.618,805.911,193.532,25.560
East,1,-17.530,29.077,809.805,186.073,33.952
East,0,-19.975,33.737,812.250,181.413,39.207
Backlash,0,0.000,0.000,812.250,181.413,0.000
Backlash,1,-4.025,5.551,816.275,175.863,6.856
Backlash,2,-7.622,11.222,819.872,170.191,13.566
Backlash,3,-10.250,16.440,822.500,164.973,19.374
North,0,0.000,0.000,819.872,170.191,0.000
North,1,-2.628,5.219,822.500,164.973,5.843
North,2,-6.473,12.253,826.346,157.938,13.858
North,3,-10.996,16.086,830.868,154.105,19.485
North,4,-15.128,20.831,835.000,149.361,25.744
North calibration complete. Angle = -54.0 deg, Rate = 25.744 px/sec, Parity = N/A
South,2,-15.128,20.831,835.000,149.361,25.744
South,1,-18.920,28.334,838.792,141.857,34.070
South,0,-22.374,33.986,842.247,136.205,40.690
Calibration complete, mount = On Camera.Guiding Begins at 2021-01-09 22:23:07
Exposure = 1000 ms
Mount = On Camera, connected, guiding enabled, xAngle = 122.2, xRate = 25.560, yAngle = -54.0, yRate = 25.744, parity = ?/?
Norm rates RA = 98.9"/s (==>) dec 0, Dec = 99.6"/s; ortho.err. = 86.3 deg
RA Guide Speed = Unknown, Dec Guide Speed = Unknown, Cal Dec = Unknown, Last Cal Issue = Orthogonality, Timestamp = 09.01.2021 22:23:07
Lock position = 842.247, 136.205, Star position = 842.247, 136.205, HFD = 6.59 px
INFO: Manual guide (Mount) East 250 ms
1,2.391,"Mount",4.000,-6.387,-7.536,-7.522,-4.805,-4.513,188,E,175,N,,,77,6.20,0
2,5.013,"Mount",7.591,-12.570,-14.682,-14.669,-10.381,-9.704,406,E,377,N,,,74,6.08,0
3,8.420,"Mount",12.399,-20.281,-23.769,-23.740,-17.359,-16.185,679,E,629,N,,,79,6.28,0
4,12.238,"Mount",19.317,-29.184,-34.990,-34.865,-25.995,-24.156,1017,E,938,N,,,94,6.86,1
5,18.409,"Mount",26.791,-41.180,-49.123,-48.973,-36.840,-34.215,1441,E,1329,N,,,79,6.28,0
6,29.387,"Mount",39.729,-58.073,-70.314,-69.992,-52.654,-48.838,2060,E,1897,N,,,83,6.44,0
7,38.333,"Mount",53.028,-76.168,-92.714,-92.240,-70.294,-65.112,2500,E,2500,N,,,80,6.32,0
8,44.936,"Mount",67.495,-89.676,-111.856,-111.014,-86.246,-79.631,2500,E,2500,N,,,85,6.52,0
9,51.542,"Mount",80.076,-104.083,-130.754,-129.678,-101.683,-93.733,2500,E,2500,N,,,90,6.71,0
10,58.149,"Mount",95.398,-120.504,-152.817,-151.419,-119.028,-109.598,2500,E,2500,N,,,104,7.21,1
11,64.754,"Mount",108.964,-133.495,-171.043,-169.310,-134.333,-123.505,2500,E,2500,N,,,76,6.16,1
12,66.335,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
13,68.096,"DROP",,,,,,,,,,,,,0,0.00,3,"Stern verloren - geringe Größe"
Guiding Ends at 2021-01-09 22:24:16
INFO: Guiding parameter change, MultiStar = falseCalibration Begins at 2021-01-09 22:26:11
Exposure = 1000 ms
Lock position = 467.249, 841.272, Star position = 476.427, 826.711, HFD = 5.54 px
West,0,0.000,0.000,479.284,821.730,0.000
West,1,-3.597,3.823,482.881,817.907,5.249
West,2,-6.310,8.490,485.594,813.240,10.578
West,3,-9.084,13.418,488.368,808.313,16.203
West,4,-11.359,17.753,490.643,803.977,21.076
West,5,-14.171,22.141,493.455,799.589,26.288
West calibration complete. Angle = 122.6 deg, Rate = 21.030 px/sec, Parity = N/A
East,2,-14.171,22.141,493.455,799.589,26.288
East,1,-18.104,28.678,497.388,793.052,33.914
East,0,-20.928,33.655,500.212,788.075,39.631
Backlash,0,0.000,0.000,500.212,788.075,0.000
Backlash,1,-3.411,5.875,503.623,782.200,6.794
Backlash,2,-6.268,11.951,506.481,776.124,13.495
Backlash,3,-9.624,17.387,509.837,770.688,19.873
North,0,0.000,0.000,506.481,776.124,0.000
North,1,-3.356,5.436,509.837,770.688,6.389
North,2,-6.902,11.176,513.383,764.948,13.135
North,3,-10.637,16.846,517.118,759.278,19.923
North,4,-14.036,22.765,520.517,753.359,26.744
North calibration complete. Angle = -58.3 deg, Rate = 26.744 px/sec, Parity = N/A
South,2,-14.036,22.765,520.517,753.359,26.744
South,1,-18.048,29.637,524.528,746.487,34.699
South,0,-21.402,35.363,527.882,740.761,41.335
Calibration complete, mount = On Camera.Guiding Begins at 2021-01-09 22:26:42
Exposure = 1000 ms
Mount = On Camera, connected, guiding enabled, xAngle = 122.6, xRate = 21.030, yAngle = -58.3, yRate = 26.744, parity = ?/?
Norm rates RA = 81.3"/s (==>) dec 0, Dec = 103.4"/s; ortho.err. = 89.0 deg
RA Guide Speed = Unknown, Dec Guide Speed = Unknown, Cal Dec = Unknown, Last Cal Issue = Orthogonality, Timestamp = 09.01.2021 22:26:41
Lock position = 527.882, 740.761, Star position = 527.882, 740.761, HFD = 5.95 px
1,4.717,"Mount",3.929,-5.976,-7.151,-7.152,-4.559,-4.291,217,E,160,N,,,276,11.49,0
2,11.054,"Mount",12.401,-21.036,-24.403,-24.384,-16.525,-15.489,786,E,579,N,,,292,11.85,0
3,14.698,"Mount",17.296,-28.754,-33.542,-33.521,-24.895,-23.211,1184,E,868,N,,,188,9.43,0
INFO: Manual guide (Mount) North 250 ms
4,19.569,"Mount",22.791,-38.323,-44.564,-44.533,-33.700,-31.362,1602,E,1173,N,,,263,11.23,0
5,28.522,"Mount",39.952,-56.998,-69.544,-69.583,-51.496,-48.022,2449,E,1796,N,,,267,11.32,1
6,34.927,"Mount",50.913,-69.861,-86.287,-86.363,-65.951,-61.422,2500,E,2297,N,,,266,11.28,0
7,41.530,"Mount",64.036,-83.459,-104.815,-104.950,-80.834,-75.255,2500,E,2500,N,,,268,11.33,0
8,48.150,"Mount",77.694,-97.068,-123.640,-123.843,-95.997,-89.357,2500,E,2500,N,,,255,11.05,0
9,54.759,"Mount",90.578,-110.946,-142.274,-142.531,-111.099,-103.390,2500,E,2500,N,,,239,10.69,1
Guiding Ends at 2021-01-09 22:27:36Guiding Begins at 2021-01-09 22:27:49
Exposure = 1000 ms
Lock position = 653.247, 581.372, Star position = 653.247, 581.372, HFD = 6.11 px
1,1.947,"Mount",3.082,-5.056,-5.920,-5.917,-3.774,-3.550,179,E,0,,,,265,11.26,0
2,3.945,"Mount",6.286,-10.303,-12.067,-12.061,-8.495,-7.946,404,E,0,,,,276,11.49,0
3,6.190,"Mount",9.876,-15.949,-18.757,-18.750,-13.763,-12.839,654,E,0,,,,273,11.42,0
4,8.695,"Mount",13.315,-21.677,-25.435,-25.424,-19.140,-17.822,910,E,0,,,,257,11.09,1
5,11.534,"Mount",16.965,-27.902,-32.646,-32.628,-24.879,-23.141,1183,E,0,,,,250,10.95,0
6,14.622,"Mount",21.220,-34.890,-40.825,-40.804,-31.313,-29.110,1489,E,0,,,,236,10.61,0
7,18.010,"Mount",25.149,-41.778,-48.744,-48.715,-37.729,-35.051,1794,E,0,,,,225,10.38,1
8,21.734,"Mount",29.767,-49.413,-57.665,-57.630,-44.779,-41.588,2129,E,0,,,,222,10.30,0
9,25.829,"Mount",34.389,-58.240,-67.591,-67.541,-52.605,-48.842,2500,E,0,,,,246,10.83,0
10,29.929,"Mount",39.404,-66.304,-77.087,-77.033,-60.321,-55.988,2500,E,0,,,,253,11.00,0
11,34.029,"Mount",44.454,-75.191,-87.294,-87.230,-68.468,-63.535,2500,E,0,,,,256,11.06,0
12,38.125,"Mount",49.565,-83.784,-97.287,-97.216,-76.570,-71.036,2500,E,0,,,,232,10.52,1
13,42.221,"Mount",55.251,-92.586,-107.766,-107.693,-84.972,-78.823,2500,E,0,,,,248,10.89,0
14,46.314,"Mount",60.427,-101.546,-118.102,-118.020,-93.347,-86.577,2500,E,0,,,,272,11.42,1
15,50.411,"Mount",65.442,-110.461,-128.314,-128.221,-101.636,-94.248,2500,E,0,,,,262,11.21,0
16,54.508,"Mount",70.311,-119.453,-138.513,-138.406,-109.900,-101.893,2500,E,0,,,,250,10.93,1
17,58.598,"Mount",75.505,-128.141,-148.631,-148.517,-118.106,-109.489,2500,E,0,,,,260,11.14,0
Guiding Ends at 2021-01-09 22:28:48Calibration Begins at 2021-01-09 22:28:57
Equipment Profile = Touptek
Dither = both axes, Dither scale = 1.000, Image noise reduction = none, Guide-frame time lapse = 0, Server enabled
Pixel scale = 3.87 arc-sec/px, Binning = 1, Focal length = 200 mm
Search region = 25 px, Star mass tolerance = 99.0%, Single-star mode
Camera = GCMOS01200KMB, gain = 0, full size = 1280 x 960, no dark, no defect map, pixel size = 3.8 µm
Exposure = 1000 ms
Lock position = 737.552, 438.314, Star position = 746.655, 423.712, HFD = 5.59 px
West,0,0.000,0.000,749.738,418.507,0.000
West,1,-2.850,4.449,752.589,414.058,5.284
West,2,-5.187,8.768,754.926,409.739,10.188
West,3,-7.900,13.258,757.638,405.249,15.433
West,4,-10.731,17.867,760.470,400.640,20.842
West,5,-13.484,22.426,763.222,396.080,26.168
West calibration complete. Angle = 121.0 deg, Rate = 20.934 px/sec, Parity = N/A
East,2,-13.484,22.426,763.222,396.080,26.168
East,1,-17.028,29.118,766.767,389.389,33.731
East,0,-20.281,33.590,770.019,384.917,39.238
Backlash,0,0.000,0.000,770.019,384.917,0.000
Backlash,1,-3.722,5.806,773.741,379.111,6.896
Backlash,2,-7.684,11.054,777.703,373.863,13.462
Backlash,3,-11.529,16.154,781.548,368.762,19.847
North,0,0.000,0.000,777.703,373.863,0.000
North,1,-3.846,5.100,781.548,368.762,6.388
North,2,-7.751,10.476,785.454,363.387,13.032
North,3,-11.777,15.851,789.480,358.012,19.747
North,4,-18.646,25.703,796.349,348.159,31.755
North calibration complete. Angle = -54.0 deg, Rate = 31.755 px/sec, Parity = N/A
South,2,-18.646,25.703,796.349,348.159,31.755
South,1,-22.895,33.036,800.598,340.826,40.194
South,0,-26.458,38.899,804.161,334.963,47.045
Calibration complete, mount = On Camera.Guiding Begins at 2021-01-09 22:29:30
Exposure = 1000 ms
Mount = On Camera, connected, guiding enabled, xAngle = 121.0, xRate = 20.934, yAngle = -54.0, yRate = 31.755, parity = ?/?
Norm rates RA = 81.0"/s (==>) dec 0, Dec = 122.8"/s; ortho.err. = 85.1 deg
X guide algorithm = Hysteresis, Hysteresis = 0.250, Aggression = 0.850, Minimum move = 0.500
Y guide algorithm = Hysteresis, Hysteresis = 0.250, Aggression = 0.800, Minimum move = 0.500
Backlash comp = enabled, pulse = 20 ms
Max RA duration = 2500, Max DEC duration = 2500, DEC guide mode = Auto
RA Guide Speed = Unknown, Dec Guide Speed = Unknown, Cal Dec = Unknown, Last Cal Issue = Orthogonality, Timestamp = 09.01.2021 22:29:29
RA/Dec = Unknown, Hour angle = Unknown, Pier side = Unknown, Rotator pos = N/A, Alt = Unknown, Az = Unknown
Lock position = 804.161, 334.963, Star position = 804.161, 334.963, HFD = 6.30 px
Frame,Time,mount,dx,dy,RARawDistance,DECRawDistance,RAGuideDistance,DECGuideDistance,RADuration,RADirection,DECDuration,DECDirection,XStep,YStep,StarMass,SNR,ErrorCode
1,2.346,"Mount",4.912,-8.499,-9.815,-9.793,-6.257,-5.876,299,E,185,N,,,280,11.56,1
2,4.884,"Mount",8.992,-14.560,-17.111,-17.030,-12.238,-11.393,585,E,359,N,,,273,11.40,0
3,7.903,"Mount",12.810,-21.166,-24.740,-24.642,-18.373,-17.064,878,E,537,N,,,241,10.72,0
4,11.489,"Mount",17.710,-29.146,-34.104,-33.964,-25.646,-23.791,1225,E,749,N,,,229,10.48,1
5,15.718,"Mount",24.549,-37.202,-44.532,-44.206,-33.839,-31.282,1616,E,985,N,,,275,11.48,0
6,20.655,"Mount",32.165,-46.915,-56.781,-56.277,-43.388,-40.023,2073,E,1260,N,,,286,11.71,0
7,26.345,"Mount",41.414,-57.636,-70.735,-69.973,-54.314,-49.988,2500,E,1574,N,,,275,11.47,1
8,32.443,"Mount",51.774,-70.071,-86.730,-85.695,-66.832,-61.415,2500,E,1934,N,,,290,11.79,1
9,38.864,"Mount",63.561,-82.757,-103.676,-102.271,-80.295,-73.646,2500,E,2319,N,,,273,11.42,0
10,45.465,"Mount",76.719,-95.990,-121.797,-119.941,-94.709,-86.694,2500,E,2500,N,,,264,11.24,0
11,52.070,"Mount",89.899,-109.773,-140.401,-138.114,-109.631,-100.207,2500,E,2500,N,,,284,11.66,0
12,58.706,"Mount",103.581,-123.589,-159.291,-156.537,-124.845,-113.964,2500,E,2500,N,,,271,11.36,0
13,65.340,"Mount",117.116,-137.495,-178.184,-174.977,-140.122,-127.779,2500,E,2500,N,,,266,11.29,0
14,71.947,"Mount",130.261,-150.964,-196.500,-192.853,-155.045,-141.268,2500,E,2500,N,,,269,11.36,0
15,78.550,"Mount",143.687,-164.884,-215.347,-211.257,-170.231,-155.008,2500,E,2500,N,,,290,11.79,1
16,85.186,"Mount",156.788,-178.832,-234.053,-229.544,-185.383,-168.728,2500,E,2500,N,,,285,11.70,0
17,91.791,"Mount",170.263,-192.898,-253.051,-248.101,-200.714,-182.606,2500,E,2500,N,,,285,11.67,0
18,98.404,"Mount",183.743,-206.721,-271.843,-266.442,-215.952,-196.387,2500,E,2500,N,,,291,11.81,0
19,105.002,"Mount",197.404,-220.578,-290.758,-284.893,-231.248,-210.213,2500,E,2500,N,,,280,11.57,1
20,111.617,"Mount",210.901,-234.285,-309.460,-303.137,-246.421,-223.925,2500,E,2500,N,,,316,12.32,0
21,118.223,"Mount",224.680,-248.222,-328.504,-321.712,-261.786,-237.812,2500,E,2500,N,,,296,11.94,0
22,124.816,"Mount",237.829,-261.760,-346.882,-339.652,-276.767,-251.353,2500,E,2500,N,,,314,12.28,0
23,131.433,"Mount",251.484,-275.691,-365.858,-358.167,-292.047,-265.171,2500,E,2500,N,,,319,12.38,0
24,134.456,"Mount",264.629,-289.474,-384.443,-376.325,-307.143,-278.829,0,,0,,,,318,12.38,0Log Summary: calcnt:7 gcnt:14 gdur:578 gacnt:0
Log closed at 2021-01-09 22:31:44
INFO: Guiding parameter change, MultiStar = falseGuiding Begins at 2021-01-09 22:32:35
Exposure = 1000 ms
Mount = On Camera, connected, guiding enabled, xAngle = 121.0, xRate = 20.934, yAngle = -54.0, yRate = 31.754, parity = ?/?
Lock position = 220.724, 616.024, Star position = 220.724, 616.024, HFD = 6.66 px
Guiding Ends at 2021-01-09 22:32:36
INFO: Guiding parameter change, MultiStar = falseCalibration Begins at 2021-01-09 22:32:41
Exposure = 1000 ms
West,0,0.000,0.000,237.379,589.943,0.000
West,1,-3.239,5.932,240.617,584.011,6.758
West,2,-6.646,11.939,244.025,578.004,13.664
West,3,-10.163,17.032,247.542,572.910,19.834
West,4,-14.042,23.273,251.421,566.670,27.181
West calibration complete. Angle = 121.1 deg, Rate = 27.181 px/sec, Parity = N/A
East,2,-14.042,23.273,251.421,566.670,27.181
East,1,-18.127,29.982,255.506,559.961,35.035
East,0,-21.354,35.254,258.733,554.688,41.217
Backlash,0,0.000,0.000,258.733,554.688,0.000
Backlash,1,-3.540,5.534,262.274,549.155,6.569
Backlash,2,-7.090,11.245,265.824,543.443,13.294
Backlash,3,-11.261,16.648,269.994,538.040,20.099
North,0,0.000,0.000,265.824,543.443,0.000
North,1,-4.170,5.403,269.994,538.040,6.825
North,2,-7.930,10.358,273.754,533.086,13.045
North,3,-11.808,16.127,277.632,527.316,19.988
North,4,-15.645,21.412,281.469,522.031,26.519
North calibration complete. Angle = -53.8 deg, Rate = 26.519 px/sec, Parity = N/A
South,2,-15.645,21.412,281.469,522.031,26.519
South,1,-20.193,28.509,286.017,514.934,34.936
South,0,-23.545,34.212,289.369,509.231,41.531
Calibration complete, mount = On Camera. -
Guten Abend!
Seit längerem habe ich ein Problem:
Ich möchte meine heq 5 Montierung auf einem Südbalkon ausrichten. Das habe ich schon einmal sehr gut hinbekommen.Vorgehensweise:
Montierung grob nach Norden ausgerichtet, Polhöhe draußen mit Polaris eingestellt.PHD 2 angeschmissen. Bevor ich den Drift Align durchführen kann, soll ich kalibrieren. Und da kommt der Fehler:
Ich suche mir einen Stern aus, PHD2 macht dann die Kalibrierung. Man sieht unten diverste Steps nach West, Stern wandert. Dann schaltet das Programm auf Ost, Stern wandert weiter in die gleiche Richtung, PHD2 fängt ihn nicht mehr ein.
Es erscheint die Meldung "Little or no east movement was measured".
Ich kann ausschließen, dass die Montierung kaputt ist, sie funktioniert sowohl per Handbox als auch per EQMOD.
Egal, was ich mache, PHD2 kann nicht kalibrieren.
Weiß jemand Rat? Ich bin echt total frustriert und weiß nicht mehr weiter.
Gavva
Ich wollte das Protokoll hier anhängen, es ist allerdings zu lang
