Hello all!
Just wanted to thank you all for your advices!
I decided to go with an achromatic refractor StarQuest 102R. I know, it was also advised against it in favor of Mak, but reading Gerd’s recommendations on eyepieces for the Mak and also checking in astrotools what field of view I will be able to see in the Mak, I thought it will be difficult for me to search in the sky with such a narrow field. Plus, now Skywatcher and Bresser Maks are not available, with delivery closer to the end of the year...
Now I have a refractor with a wide field, and already was able to find some of the Messier objects in the sky. Especially thank you for recommendation to get a rear view telescope - I’m definitely making use of it locating M57 which is rather high in the altitude.
Chromatic aberrations are visible, that’s true. But even with them I can see details like red spot on Jupiter and its striped atmosphere. The only disappointment is Mars. It’s too bright, so appears only as a bright disk with no details.
Also positive thing - I haven’t used all my budget so now I’m looking what eyepieces I can add to the standard Skywatcher set, so any recommendations would be great
And in addition I’m monitoring ebay for a second-hand Mak 100 to have a better device for the planets.
BTW, the mount is not bad, maybe I do not have proper comparison, but this one is easy to use and not very wobbly. I’m using it in EQ mode, and even w/o Polaris view it’s easy to set up.
