Beiträge von MaettesC im Thema „Klein aber fein: der neue 8“ f/7 ist fertig“
    bisher leider immer noch nicht als Wolken, daher leider noch kein First Light Bericht. Ich habe allerdings noch Carl Zambutos Einschätzung zu der Frage von Konrad (fastride) bezüglich des Öffnungsverhältnisses. Carl hat den Beitrag hier gelesen und mir seine Einschätzung zu Konrads Frage gemailt, die ich in seinem Namen hier einfügen darf:
    "Someone on the site asked about whether F/6 is good enough and why go longer.
    The secondary obstruction is the least concern. I think the real reasons are three-
    One, coma is present to some degree inside of 19mm at the focal plane until you get to F/10. Clyde Tombaugh
    observed through a 16” F/10 telescope for planet purpose.
    Two- a longer focal length produces greater magnification with a given eyepiece, which is also a smaller exit pupil
    and darker sky (background). This is better for contrast.
    Three, eyepieces that correct for coma are not necessary because the field is already flat. This allows for
    more pristine eyepieces that are geared toward observing and not wide field “showpiece" views. Long focus
    is great for Aus Jena and Zeiss eyepieces for example.
    You already know all this.
    Those who are veteran observers such as yourself know that longer is always better. The only advantage
    of shorter focal length is compactness of the telescope. I think the F/3 telescopes that are not for wide field use
    but rather for being very large and very compact are stupid. I NEVER hear any rave review about quality of view.
    I once evaluated a mirror that would now be 140 years old. It was made by Hereford With.
    He only star tested for bench results. It was an 8” at F/12. I have planet photos taken with the mirror, they are superb.
    Again, fabulous build on your scope, and I’m glad its at F/7 instead of F/6. My favorite telescope of all time was a 10” F/7.
    Carl"
    Liebe Grüße,
    Matthias
    Hallo Roland,
    ganz vergessen: der Tubus ist ziemlich exakt 1,43 m lang. Hatte ihn eben mal auf dem Arm und bin auf meine Personenwaage. Abgesehen von der Erkenntnis, dass ich mal wieder zum Sport gehen könnte, kam heraus, dass der Tubus trotz den drei Kilo Gegengewicht 11,1 kg wiegt. Ein Wert, mit dem ich durchaus leben kann.
    Lieben Gruß,
    Matthias
    Hi Roland,
    Zambuto garantiert mit einem Zertifikat eine Vergrößerung bis zum Doppelten der Öffnung ohne Leistungseinbruch. Das wäre laut ihm das Minimum, was er (Seeing natürlich vorausgesetzt) auf jeden Fall garantieren kann. Darüber hinaus wäre aber immer noch einiges möglich. Er hat von einem Kunden berichtet, der mit 10" und über 1000x enge Doppelsterne trennt. Bleibt erstmal abzuwarten, ob ich tatsächlich mal eine Nacht erwische, wo das seeingmäßig überhaupt drin wäre. Mit dem 12" f/5 war auch immer unterhalb der doppelten Öffnung Schluss :)
    Eine EQ-Plattform habe ich von Anfang an für das Teleskop im Auge gehabt. Hier werde ich wohl ebenfalls wieder bei Dieter Martini zuschlagen, allerdings möchte ich diese Anschaffung noch etwas hinaus schieben. Aber bei derartiger Übervergrößerung muss das Teil schon recht präzise aufgestellt werden... :)
    Die Teilkreise siehst du unten an der Azimutachse und in dem der Kamera zugewandten Höhenrad. Die "schwarzen Teile". Da werden nur noch Kabel eingesteckt, die dann mit dem Nexus DSC verbunden werden und schon geht's los.
    Zu den Kosten: beide Spiegel haben mit Einfuhrumsatzsteuer und versichertem Luftfrachtversand zusammen rund 1900 € gekostet. Die Rockerbox mit den digitalen Teilkreisen lag bei etwas über 700 €, der Tubus bei etwas über 1500 €. Der Rest ging dann für diversen Kleinkram (Gegengewichte, Material für die Tubusentlüftung etc) drauf.
    Lieben Gruß,
    Matthias
    vielen Dank für euer Feedback. Erstmal noch wie gewünscht ein Foto mit Binoansatz (auf dem Foto zusammen mit 2x Delos 12 mm):
    (==>) Hannes: die Nagler kenne und mag ich selbst sehr gerne. Hatte früher am 12" Dob auch einige im Einsatz, allerdings nicht die ganz kurzen. Leider haben die zusammen mit dem Dob den Besitzer gewechselt. Rückblickend vielleicht ein Fehler, aber mit meinen aktuelle Okularen bin ich auch hochauf zufrieden. Die da wären ES 30mm 82 Grad, 18 mm 82 Grad, 12 mm 92 Grad (absoluter Liebling!), 9 mm 100 Grad und 6,7 mm 82. Dazu paarweise fürs Bino Panoptic 24mm und Delos 12mm. Eine gute Barlow stand schon lange auf meiner Liste, um mit dem 12 mm und 9 mm in höher vergrößernde Bereiche zukommen. So hab ich dann gestern Abend noch die 2x Powermate in 2" bestellt und dazu das ES 4,7 mm. Wenn das mit der Übervergrößerung gut klappt bei entsprechenden Bedingungen, kann ich die kurzen ES auch ohne großartigen Verlust weiterverkaufen und dann immer noch auf Nagler schwenken. So erstmal der Plan, sollte ich an den kurzen ES etwas auszusetzen haben [:D] Die Encke-Teilung steht auch bei mir ganz oben auf der Wunschliste. Aber da werden wir wohl erst noch ein paar Jährchen Geduld haben müssen bei der aktuellen Planetenstellung... Wenn es denn überhaupt klappt mit 8" [;)]
    (==>) G2-Astro: vielen Dank! Hoffentlich stellt sich der Spaß bald ein, wenn endlich mal gescheites Wetter ist. Erst einige Monate Wartezeit, bis alles zusammen ist und dann spielt das Wetter nicht mit... Typisch [:p] Die Idee mit dem Teppich ist ne gute Sache! Allein schon, dass man nach einem Absturz keine Wiese per Taschenlampe absuchen muss :) Um die Holzlasur, zumindest in farbloser Optik, werde ich wahrscheinlich nicht herum kommen, wenn ich es genau bedenke. Bringt mir ja nichts, wenn das Holz mit der Zeit aufquillt. Schaue mir mal an, was du da so empfohlen hat. Vielen Dank. Einen langen Weg zum Beobachtungsplatz hab ich zum Glück nicht und kann mir diese "Bastelarbeit" sparen. Entweder, es geht raus in den Garten für Mond und Planeten, bzw helle DS-Objekte, oder ich fahre rund 30 km in die Eifel und stelle mein Auto direkt neben einer Parkbank ab, vor der ich das Teleskop aufbaue. Hier hab ich einen relativ dunklen Landhimnel zur Verfügung [:D] Trotzdem bin ich an deinen Entwürfen sehr interessiert. Zeig mal gerne, wenn's soweit ist!
    Lieben Gruß,
    Matthias
    so... Endlich Feierabend [:p]
    (==>) Marcus: Hab's noch nicht geschafft, ein Bild mit dem Bino im OAZ zu machen, aber das sollte morgen klappen. Dank Homeoffice [:D]
    (==>) Andreas: ja, du hast Recht, der OAZ sitzt relativ weit oben. Das entspricht aber leider auch der maximalen Tubuslänge, die quer in meinen Kofferraum passt [:D] Ich hatte eh vor, noch einen Streulichtschutz zu bauen, den ich zum Transport abnehmen kann. Mir fehlt aber noch die Inspiration, was ich da machen soll. Hatte erst an DC-Fix Folie in Cabonoptik gedacht, aber der Unterschied zu dem "echten Carbon" direkt daneben sieht komisch aus...
    (==>) Konrad: ja, ich hatte vor, die Rockerbox so zu lassen. Irgendwie macht gerade der Kontrast zwischen Carbon, einem eher modern anmutenden Werkstoff und dem zumindest in der Oberfläche sehr natürlich aussehenden Holz die Optik aus. Nicht, dass mir wichtig wäre, wie mein Teleskop aussieht, dass "Durchsehen" ist mir deutlich wichtiger, aber irgendwie finde ich, hat es schon was [:)] Außerdem hatte ich mal eine allergische Reaktion bei einem Holzlack und auch deshalb lass' ich's gerade so, wie's ist [:p]
    (==>) Hannes: witzig, genau das hat mir Carl Zambuto auch gesagt. Der übrigens noch lange nach Verkaufsabwicklung regen Mailverkehr gehalten hat. Gutes after sales menagement würde man das heute nennen [8D] Er sagte jedenfalls, dass er viele Kunden hat, die davon berichten, bei wirklichem Ausnahmeseeing stark übervergrößern zu können. Da scheint ja dann schon was dran zu sein... [:D] Taukappe kommt wie gesagt noch dran... Nur fehlt mir halt noch die zündende Idee...
    (==>) Holger: ja, ich denke, das wird sich ganz gut ergänzen. Aber ich habe mit dem Newton bei weitem nicht nur Mond und Planeten zum Ziel. Deshalb sind auch die Teilkreise dabei, die mit dem Nexus DSC und bei Bedarf auch darüber Verbindung zum Tablet mit Skysafari haben. Bisher bin ich nur Telrad bzw Riegel und DS Reiseatlas gewohnt. Das wird also schon neuer Luxus für mich sein. [:p]
    (==>) Roland: die Lüftereinheit sehe ich eher noch als eine Art Prototyp an :) Nach dem bauen sind mir gleich einige Verbesserungen eingefallen, die ich vielleicht in einem nächsten Entwurf noch umsetzen werde. Aber bis dahin ist diese hier erstmal gut genug denke ich.
    An Okularen bin ich im Mittelfend der Abstufung ganz gut ausgestattet. Wobei meine beiden Teleskope mit f/5 und f/7 am oberen und unteren Ende der Okularpalette schon gerne noch ergänzt werden wollen. So wäre am Dobson schon ruhig noch etwas mehr AP, als die vom ES 30mm 82 Grad mit rund 4,30mm möglich, während das Okular am Refraktor gut passende 6mm liefert. Aber z.B. für 0,2 Grad wGf mehr beim 41mm Panoptic gleich wieder viel Geld in die Hand zu nehmen, das ist es mir nicht wert. Zumal ich ja den Reffi für maximales Feld habe.
    Am hochvergrößernden Ende bin ich gerade kurz vor der Kaufentscheidung. Als erstes wird eine 2x Powermate in 2" angeschafft. Damit aus meinem 12 mm ES 92 Grad, meinem Lieblingsokular, ein 6 mm mit 236x Vergrößerung zu machen und dann den Terminator entlang zu surfen, lässt mir schon das Wasser im Mund zusammen laufen [:D] Mein ES 9 mm 100 Grad wird dann zum 4,5 mm mit 315x, womit ich das seeingbedingte Maximum der meisten Nächte ausreizen dürfte [:I] Dann hätte ich noch ein 6,7 mm ES 82 Grad, was mit Borlow 423x liefert, womit es schon in die Übervergrößerung geht. Bei sehr guten Nächten stelle ich mir das schon machbar vor. Dann würde ich samt der Barlow noch das ES 4,7 mm 82 Grad bestellen, was ohne Barlow wahrscheinlich häufiger einsetzbare 301x liefert und mit Barlow satte 602x, was gradezu nach verrückten Experimenten an Doppelsternen schreit [:D] Da ich das kurze Ende der Okularpalette eher selten einsetzbar sehe, belasse ich es hier bei den ES, bevor ich viel Geld für Delos und Co. in die Hand nehmen möchte. Die meiste Zeit möchte ich eh am Bino verbringen, wo ich 2x 24 mm Panoptic und 2x 12 mm Delos im Einsatz habe. Zusammen mit dem Filterswitch des Binos habe ich hier pro Paar drei Vergrößerungen und liege damit zwischen 77x und 354x, bzw zwischen 2,6 und 0,6 mm AP. Für monokular dann nur noch die Barlow und das 4,7 mm ES, dann hab ich endlich alle sieben Sachen zusammen :)
    (==>) Konrad: der Abstand zwischen Spiegelrand und Tubusinnenseite Beträge ziemlich exakt 21 mm. Könnte etwas mehr sein, aber das gleicht der Lüfter wieder aus.
    (==>) Martin: der Streulichtschutz kommt auf jeden Fall noch dran. Aber welche Schrauben meinst du genau an der HS-Zelle?
    (==>) Statis: vielen Dank. Der Tubus misst innen rund 245 mm, die Wand ist knappe 4 mm stark. Für den Tubus samt OAZ, HS-Zelle und Spinne habe ich knapp 1500 € gezahlt. Für das kommplette Teleskop samt Rockerbox und den Teilkreisen waren es rund 4500 €.
    Das mit den Laufgewichten erschien mir auch seltsam. Eigentlich wollte ich sie auf der Unterseite des Tubus anbringen. Um sicher zu gehen, was wirklich besser funktioniert und bevor ich den Tubus unnötig falsch anbohre, habe ich das Gewichtsystem mit Panzertape nacheinander an den infrage kommenden Positionen fixiert und dann alle Okulare samt Bino durchgetestet. Mit den wenigsten Änderungen an der Gewichtposition zur Ausbalancierung kam ich komischwerweise in dieser Position hin. Es sieht zwar etwas seltsam aus, aber mir stand die Funktionalität im Vordergrund. Und die passt so erprobter- aber komischer Weise, tatsächlich am besten :)
    Die Rockerbox steht wirklich sehr solide. Auf der Vorderseite befindet sich eine dicke Querstrebe und die Winkel sind ebenfalls verstärkt. Das Material ist dickes Birke Multiplex. Da zittert nichts. Beim Test am Tag ist bei 212x jedenfalls keinerlei Nachwingen bemerkbar.
    Der Gummi unter den Azimutfüßen ist ziemlich hart. Der soll mir in erster Linie auch etwas die hölzernen Füße schützen, wenn der Dobson auf dem Acker steht. Auf hartem Untergrund werden Schwingungen von z.B. festen Schritten neben dem Teleskop etwas abgefedert. Mag aber auch Einbildung sein, da das "Vorher-Bild" schwer zu erinnern ist, um es realitisch einzuschätzen.
    Ich bin auf jeden Fall auf den ersten Praxistest gespannt. Weitere Verbesserungen werden sich dann sicherlich über die Zeit ergeben. Aber bisher bin ich auf jeden Fall vollauf zufrieden [:D]
    Vielen Dank für euren Input und liebe Grüße, wurde ja jetzt doch schon wieder ganz schön viel Text [:)]
    Matthias
    vielen Dank für die Rückmeldungen und warmen Worte [:D]
    Auf der Arbeit geht's heute etwas heiß her und ich komme noch nicht dazu, auf die Fragen einzugehen, hole ich aber nach!
    Eins sei nur vorweg gesagt: eine Taukappe / Streulichtschutz kommt natürlich noch. Ich hätte auch gleich den Tubus etwas länger lassen können, aber dann ist der Transport halt wieder doof [:I] Also wird noch was abnehmbares montiert.
    Lieben Gruß,
    Matthias
    die hochgeladenen Bilder sind jetzt freigeschaltet. Ein Bild samt Bino im OAZ reiche ich dir noch nach Marcus. Hatte heute Nachmittag nur ein mit dem ES 12mm 92 Grad im OAZ gemacht[:)]
    Einmal das Teleskop im ganzen:
    Hauptspiegelzelle und Rückseite des Spiegels:
    Die Gegengewichte:
    Blick von vorne in die Öffnung, gegenüber des OAZ ist Velourfolie verklebt, der Rest ist solide mit matter Farbe geschwärzt:
    Tubusentlüftung mit zwei PC Lüftern und Regler:
    Lieben Gruß,
    Matthias
    dank Corona hat‘s etwas gedauert mit den Lieferzeiten der einzelnen Komponenten, doch nun ist er endlich fertig.
    Aber zunächst von Anfang an... vor einigen Jahren hatte ich bereits einen 12“ f/5 von GSO, der mir mit der Zeit irgendwann einfach zu unhandlich und unbequem wurde, um ihn immer raus auf den dunklen Acker zu fahren. Der Spiegel war auch alles andere als makellos, aber schon brauchbar. Also habe mich schweren Herzens davon getrennt und nach einer kurzen Astropause einen 120/600 Richfield Refraktor angeschafft.
    Dieser leistet seitdem gute Dienste bei der Beobachtung von ausgedehnten DS-Objekten und ist sehr schnell einsatzbereit. Da dann irgendwann wieder das Öffnungsfieber stieg und noch eine schöne Ergänzung für die Mond- und Planetenbeobachtung angeschafft werden sollte, bin ich nach langem Hin und Her beim 8“ Dobson gelandet.
    Dieser stellt für mich persönlich den bestmöglichen Kompromiss zwischen Leistung, Einsatzgebieten und Aufwand in der Handhabung dar. Also entschloss ich mich, mir das Teleskop so zusammen zu stellen, dass für mich keine Wünsche mehr offen bleiben. Als dann bei Zambuto ein bereits fertiggestellter 8“ f/7 Spiegel angeboten wurde, ging es los...
    Zu den Eckdaten:
    Der Hauptspiegel ist wie gesagt ein 8“ f/7 von Carl Zambuto mit 1417mm Brennweite. Als Sekundärspiegel habe ich mir einen Antares 1,52“ (38,6mm) mit 1/30 Wave PV geordert. Die Obstruktion liegt damit bei rund 19 %. Sicherlich wäre hier auch weniger machbar gewesen, aber Carl meinte aus eigener Erfahrung, solange die Obstruktion bei unter 20% bleibt, würde er immer den etwas größeren Spiegel bevorzugen wegen der besseren Ausleuchtung. Hab ich ihm einfach mal so geglaubt, ohne selbst groß zu recherchieren. Er meinte, unter 20 % wäre der Zugewinn an Kontrast eigentlich kaum noch merkbar und daher wählt er selbst auch immer den größeren FS. Dem hab ich mich dann einfach mal so angeschlossen [:D]
    Als Tubus habe ich mich für den TS ONTC Carbontubus entschieden, den TS nach meinen Vorgaben samt der 9-Punkt HS-Zelle und der FS-Spinne gefertigt hat. Daran verbaut ist ein 2“ Moonlite Okularauszug. Für die Balance wäre sicherlich ein kleiner Helikalfokussierer sinnvoller gewesen, aber da an dem Dobson auch mein schweres Denkmeier-Bino zum Einsatz kommen soll, wollte ich schon eher einen tragfähigeren Okularauszug.
    Die Rockerbox habe ich mir von Dieter Martini bauen lassen. Für meinen alten 12“ f/5 hatte ich mir seinerzeit ebenfalls dort eine Rockerbox gekauft und war von dem Design mit den Höhenrädern fest mit den Rohrschellen verbunden sehr angetan. Die aktuelle Rockerbox habe ich gleich mit 10000 Step Encodern ausrüsten lassen, um mein Nexus DSC zu verwenden. Zur Schwingungsdämpfung und besseren Fixierung des Tubus habe ich die Innenseiten der Rohrschellen mit Streifen aus robustem 4mm Schuhsohlengummi beklebt, ebenfalls die drei Füße der Rockerbox.
    Da die bei mir verwendeten Okulare zwischen knapp 200 gr und fast 2 kg (Bino mit 2x 12mm Delos) wiegen, war natürlich die Balance noch so eine Sache... Die Rockerbox bietet zwar die Möglichkeit, das Teleskop in den Rohrschellen auszubalancieren, aber das ist mir in der Praxis während des Betriebs deutlich zu viel Aufwand. Daher habe ich mich entschieden, mit Laufgewichten zu arbeiten, die ich auch unmittelbar vor dem Okularwechsel bzw. währenddessen, mit einer Hand umpositionieren kann. Hier habe ich mich für das Laufgewichtsystem von Geoptik entschieden, welches eigentlich für 8“ SC Teleskope angeboten wird. Passt aber auch wunderbar auf den 8“ Newton Tubus.
    Damit konnte die Rockerbox sehr niedrig gehalten werden (weil der benötigte Spielraum zum Ausbalancieren in den Rohrschellen nicht benötigt wird), was die ganze Konstruktion sehr stabil und schwingungsunanfällig macht. Am Heck des Tubus sind nun 3x 1kg Gegengewichte auf einer Laufschiene montiert. Bei voller Zuladung mit dem Bino reicht es, die drei Gewichte am unteren Ende der Laufschiene zu fixieren.
    Bei monokularer Beobachtung nehme ich das untere Gewicht raus und die beiden verbliebenen wandern auf der Schiene möglichst nah an die Höhenachse der Rockerbox. Kommen nun schwere Übersichtsokulare zum Einsatz, wandert eines der beiden Gewichte wieder nach unten und die Balance passt wieder. Das alles ist mit einer Hand zu bewerkstelligen, während die andere Hand das Teleskop bei Bedarf am Höhenrad in Position hält und das Okular wechselt.
    Trotz den drei Kilo „unnützem Balast“ der Gegengewichte ist alles noch so schön leicht, dass ich Teleskop samt Rockerbox in einem Gang nach draußen befördern kann.
    Zur Tubusentlüftung habe ich mir eine Platte etwas größer als der Tubusdurchmesser aus einer 20mm Polstermaterial-Platte (Shorehärte 30 Grad) ausgeschnitten und darin zwei PC Hochleistungslüfter mit Regelung verbaut. Den Rand der Platte habe ich nach innen verjüngend zurechtgeschnitten, sodass man die Lüftereinheit quasi wie einen Korken auf das untere Tubusende aufdrücken kann. Versorgt werden die Lüfter mit einer Powerbank über USB. Durch das Polstermaterial werden die Schwingungen der Lüfter selbst bei voller Kraft absorbiert.
    Wie es ja leider so üblich ist bei Neuanschaffungen, ist nun erstmal schlechtes Wetter angesagt. Ein erster Test der Mechanik am Tag hat jedenfalls offenbart, dass der Gewichtswechsel während der Beobachtung reibungslos funktioniert, die Rockerbox sehr solide steht und auch bei hoher Vergrößerung so gut wie nicht nachtschwingt. Die Gleitlager aus Teflon und Ebony Star brechen ohne spürbaren Widerstand los und bleiben sauber stehen, wo ich das Teleskop loslasse. So soll‘s sein!
    Der Tubus ist sehr stabil und verwindungssteif bei niedrigem Gewicht, die HS-Zelle macht auf mich ebenfalls einen sehr guten Eindruck. Die FS-Halterung und Spinne wollte ich in der ersten Planung durch eine aus Carbon von Drehen und mehr ersetzen. Das erachte ich inzwischen aber als überflüssig, da die mit dem Tubus gelieferte wirklich solide ist und bereits über sehr dünne Streben verfügt. Alles in allem wird die Justage sehr stabil gehalten. Ich hatte den Tubus nun häufig auf dem Tisch liegen und immer mal wieder nach draußen getragen und aufgebaut, ohne dass sich etwas verstellt hätte. Justiert habe ich übrigens mit einem 2“ Concenter-Okular und einem Hotech Justierlaser.
    Die optischen Qualitäten konnte ich bisher wegen des Wetters lediglich am Tag testen. Ein Baum in rund 500m Entfernung lies auf seinen Blättern die Blattaderungen erkennen, das Bild war im 6,7mm ES 82 Grad (mehr Vergrößerung als 212x geben meine Okulare aktuell nicht her) gestochen scharf.
    Während ich diesen Text hier auf meiner Terrasse verfasst habe, bot sich zwischendurch einmal die Gelegenheit, in einer Wolkenlücke den Mond bei Tageslicht zu betrachten. Natürlich auch wenig aussagekräftig, aber es zeigt sich selbst am Tag schon, dass die Optik wohl einiges können wird! Ich fiebere also der ersten klaren Nacht entgegen... [:D]
    Ich habe noch auf die Schnelle eine Handvoll Bilder vom Teleskop gemacht, die ich hier nachreiche, sobald sie freigeschaltet wurden. Ein ausführlicher Bericht zum First Light wird dann noch folgen, sobald das Wetter mitgespielt hat. Bei allem, was ich bisher von dem Teleskop so gesehen hab, bin ich jedenfalls guter Dinge, dass mir das Teil sehr viel Spaß machen wird!![:p]
    Liebe Grüße,
    Matthias
    PS: über die Sinnigkeit der Anschaffung eines 8“ Newtons, für den man auch locker 20“ von der Stange hätte kaufen können, lässt sich natürlich vortrefflich streiten. Für mich sind 8“ jedoch das praktikable Maximum und das wollte ich dann einfach so gut es geht umsetzen. Klein aber fein eben[8D]
