Beiträge von denis0007dl im Thema „Carl Zeiss Sharpest binoviewer *NEW GENERATION*“
    24 pieces available!
    #8203;All items are NEW, not used!
    Finally, its only binoviewer with smallest IPD ever made, 46mm!
    Optional: my Signature possible at your demand (second picture in ad).
    Its SHARPEST binoviewer ever made, which will lasts for a lifetime!
    Binoviewer is suitable for most demanding observers!
    Thats only binoviewer in the world who produce pure crystal clear picture of any observed objects, with ZERO annoying colours added, while ALL other binoviewers with all prisms system produce some tiny amount of unwanted colours on observed objects!
    Collimation is setted on 100%, and if needed to adjust it anytime, can be done very easily by END USER (VERY important feature) by simple shifting eyepeice holder plates!
    Speciications:
    - high quality all metal binobody
    - easy collimation possible by END USER - collimation instructions included with purchase
    - 1 air-to-glass surface less than common binoviewers - that results with less scattered light, more sharpness, more contrast and better light transmittion
    - precisely, ultra fine polished, high quality made mirrors, scratch proof , with 99% reflective surfaces across all to the extreme ends of the visual spectrum
    - precisely, ultra fine polished, high quality made beamsplitter, with famous modern Carl Zeiss T* anti-reflective multi-layer coatings, which made beamsplitter invisible
    - beamsplitter and mirrors diameter 25mm
    - 23mm effective Clear Aperture
    - no annoying polarisation effect like common binoviewers have
    - T2 bayonet connection on telescope side
    - IPD: 46mm - 77.5mm
    - light path: 13.5cm with installed Baader eyepeice holders
    - weight: 590 grams ONLY with all included equipment
    Optics and mechanics Made in Germany!
    In setup are included:
    -1x Carl Zeiss SHARPEST binoviewer
    -2x custom made T2 ALU plates
    -2x Baader T2 eyepiece holders with very fine and precise adjustable diopters, and rotation locking screw mechanism - compression ring type, so no set screw marks on eyepieces. They can be very easily changed/replaced with any other T2 eyepiece holders if you want - just unscrew them
    -1x Baader Quick Changer
    -1x Baader T2 to 1.25 inch telescope adapter - compatibile with Baader Glass Path Correctors
    -2x 1.25 inch protective covers for binoviewer front side
    -1x 1.25 inch protective cover for binoviewer back side
    I cover shipping anywhere worldwide!
    Included lifetime support and paperworks: Binoviewers Certificate + Collimation instructions - all Signed by me.
    Price for each piece 1026 euros shipped.
    Contact via PM or denis0007dl et gmail.com
    or via Whatsapp, Viber or phone 00385 95 3655 744
    https://ibb.co/yQH5Gqv
    https://ibb.co/q14Vq6c
    Kind regards and all best
    Denis, binoviewers expert
