Beiträge von Han59 im Thema „Neues Plate-solving Programm“
    Die Software Entwickelung geht weiter:
    <i>The development continuous. The latest ASTAP version 0.9.92 has a blink routine (for FITS files) to detect minor planets or nova or just make a video of a comet moving:
    Youtube demonstration:
    https://youtu.be/7cheLI-3ggQ
    At the moment the blink sequence can't be exported, but you could capture it by a screen capture program.
    So ASTAP has become more a software suite. The main functionalities are:
    - FITS viewer and manipulator including annotation of deep sky objects and stars.
    - Stacking program, blinker
    - Plate solver with two types of command line interfaces, remote accessible.
    </i>
    Zurückmeldungen, Verbesserungsvorschlage sind Willkommen.
    MfG
    Han
    The new blink tab:
    Hallo Dirk,
    Die genutzte Compiler Lazarus/FPC hat keine Probleme mit OSX. Leider fehlt mir eine virtualen Maschine mit MAC OSX. Apple macht es nicht leicht.
    ASTAP hat drei Funktionalitäten: FITS Viewer, Stack Programm und Plate-Solving.
    MfG
    Han
    Die Niederlande
    Neuste Erweiterungen Stack routine ASTAP Programm:
    The lastest ASTAP version 0.9.84 can import almost any raw image from DSLR using the program DCRAW by Dave Coffin.
    DCRAW is included with the ASTAP Windows edition and can be installed in Linux by the "sudo apt-get install dcraw" command.
    The convert option is in the pulldown menu under TOOLS. ASTAP will execute DCRAW with parameters -D -4 and this will produce 16 bit monochrome PGM raw files. ASTAP can read these PGM files and convert them to 16 bit FITS files.
    After conversion the intermediate PGM are no longer required and can be deleted manually. The FITS can be used in the stacking. The Bayer de-mosaic conversion to colour will be applied later in the stacking process. With this method the full depth of the original RAW files will be preserved.
    ASTAP is still in active development and features are added. Other additions are:
    1) Colour conversion matrix E.g for bi-colour images:
    Red:=Ha
    Green: OIII
    Blue:=0.8*OIII+0.2*HA
    2) Super-pixel de-mosaic routine which could be useful if you image H-alpha with a OSC sensor and want to to extract the red channel noise free. .
    3) One star alignment for comet stacking.
    4) Star annotation up to magnitude 18 for asteroid hunting.
    Your feedback (Deutsch/English) will help with development.
    Han
    Using the RAW import routine, one user made this image:
    Befehlszeile Problemen "kein database" sind mit Astap version ß0.9.50 behoben.
    Version ß0.49 and ß0.49 have a problem using the command line. They can't find the star database. This is solved in version ß0.9.50
    Han
    Für diejenigen, die interessiert sind oder diejenigen, die ein Plate-Solving Programm verwenden können:
    Das kostenlose ASTAP Programm hat jetzt einen eigenen Plate-Solving routine. Es kann Bilder im FITS-Format aber auch JPG, PNG, TIF-Datei verarbeiten und gibt die Bildmitte Position und Orientierung.
    Das Programm ist mit der PlateSolve2 Befehlszeile kompatibel und erzeugt eine ähnliche APM-Datei. Es kann auch die FITS-Header aktualisieren oder JPG, PNG, TIF in das FITS-Format konvertieren.
    Andere Ausgabeoptionen sind WCS- oder INI-Dateien, die die Lösung enthalten.
    Dazu kommt ein flexibles Viewer- und Stacking-Menü für FITS-Dateien.
    Mit einer guten geschätzten anfang Position ist die Lösung innerhalb von Sekunden gefunden. Mit einem Offset von 20 Grad in Minuten.
    Verfügbar für MS-Windows und Linux. Noch in Entwicklung und in der Version ß0.9.48. Es ist bereits in CCDciel https://www.ap-i.net/ccdciel/en/start (CCD Capture Software) als externes Plattenlösungsprogramm integriert.
    Feedback ist willkommen.
    Han
    Die Niederlande
    Link und Download:
    http://www.hnsky.org/astap.htm
    Command line:
    http://www.hnsky.org/astap.htm#command_line
    PlateSolve2 substitute:
    http://www.hnsky.org/astap.htm#platesolve2
    Ubuntu/Debian users can install ASTAP from Astronomy Linux Packages repository:
    https://astronomylinux.ap-i.net/en:news:start
    For plate solving a star database of 420mbytes needs to be downloaded and extracted to the program directory. It has in principle only three settings,
    1) start magnitude
    2) limiting magnitude
    3) search radius in degrees. The limiting magnitude is a value for the faintest stars in an image of 10 seconds exposure. For FITS this value is automatic adapted to the exposure time. For other formats this has to be manually entered or specified in the command line. There is no need to define the pixel scale or the image astronomical size.
    It uses four star pyramids for alignment as shown below:
