Bei ATIK Kameras wird empfohlen die Core SW zu installieren und dann den ASCOM Treiber zu verwenden. Allerdings gibt es auch ein MaximDL plugin.
Von der ATIK Homepage:
<i>"MaxIm Plugin
The MaxIm plugin has been removed from the installer. It is recommended that you use ASCOM instead. However, you can download the plugin below. You will need to copy the files into the MaxIm directory in program files (Usually C:\Program Files (x86)\Diffraction Limited\MaxIm DL Vx)"
</i>
