ONLY 1 PIECE AVAILABLE!!
Beautifull, unique, LIMITED EDITION, airbrush painted!!
Thats tottaly NEWLY IMPROVED version of Leica BIG WORLDBEST binoviewer!
Whats improved?
1. ALU T2 male adapters on each eyepeice side! Each user can switch between any T2 photo and/or visual desirable equipment! It is possible even to combine sides, where on one eyepeice side, you can use eyepeices, and on other side you can use some quality cameras, or any other equipment you want! That turns binoviewer to multi-universal system
2. easy collimation can be done by end user
3. INOX T2 bayonet on telescope side
Binoviewer is SUPERCHARGED and MODIFIED!
Supercharge certificate included and signed by me.
This binoviewer is suitable for most demanding observers!
Its best possible addition to your premium APO, Newton, Mak Newt or any other telescope!
Collimation is setted on 100%, and can be done very easily by end user!
Specifications:
- high quality binobody
- easy collimation possible by end user - collimation instructions included with purchase
- high quality all prisms inside made by German Schott glass
- precisely polished all glass surfaces
- high light transmittion
- prisms diameter 28mm
- 28mm Clear Aperture (Supercharged), vs 26mm Clear Aperture originally on left eyepeice side
- 28mm Clear Aperture (Supercharged), vs 26mm Clear Aperture originally on right eyepeice side
- 25mm Clear Aperture (Supercharged), vs 22mm Clear Aperture originally on telescope side
- no annoying polarisation effect like common binoviewers have
- T2 INOX bayonet connection on telescope side - accepts Baader Glass Path Correctors
- IPD: from 55mm to 75mm
- light path: 12.8cm with included Baader eyepeice holders
- weight: 950 grams with all included equipment
Optics and mechanics Made in Germany!
In setup are included:
- 1x BIG Leica binoviewer
- 2x custom made T2 ALU plates on each eyepiece side
- 2x Baader eyepiece holders with adjustable diopters
- 1x custom made INOX T2 bayonet on telescope side
- 1x Baader Quick Changer
- 1x Baader T2 to 1.25 inch telescope adapter - accepts Baader Glass Path Correctors
- 2x 1.25 inch plastic female protective covers for front side of binoviewer
- 1x 1.25 inch plastic male protective cover for back side of binoviewer
I cover shipping anywhere worldwide.
Included lifetime support and collimation instructions.
Kind regards and all best
Denis, binoviewers expertONLY 1 PIECE AVAILABLE!!
Whats improved?
Specifications:
Contact me directly on email denis0007dl et gmail.com or via PM.
