Be aware that Baader Mark V binoviewers are NOT avaiable for purchase anywhere in shops untill 30.12.2016., except if some dealers have it on stock!
This unit is already Supercgarged!
With Supercharge service:
--you absolutely do not loose in opticall performance
--performance is not affected by anything like internal reflections and simillar
--opticall performance is improved a LOT, and you get much more Clear Aperture on your binoviewer
--you can catch more light from your fast scopes
--you are able using longer focal lenght eyepeices with bigger FOV.
Specifications are:
---30mm prisms
---on left eyepiece side there is 30mm CA prisms (Supercharged), while on Mark V it is 28mm CA
---on right eyepiece side there is 28mm CA prisms(Supercharged), while on Mark V it is 26mm CA
---on telescope side you have full 30mm CA prisms (Supercharged), while on Mark V it is 28mm CA
---T2 connection on the telescope side
---Fine focusing and diopters compensation on both sides
---1.25 inch Baader Click Lock eyepiece holders - self centering
---all metal design
---easy collimation possible
Package include:
1x Baader Mark V bino
1x Baader T2 female to Zeiss Bajonet Part of T2 fast coupler
1x Baader Adapter from 2 inch to T2 - 2 inch focal adapter
1x 1.25x Baader Glass Path Corrector
On body and one eyepeice holder, and GPC and 2" adapter there are some signs of use (little paint missing parts - scratches), but all works perfectly well!
My price for this setup is 920 Euros with included PayPal fees and shipping to worldwide.
Satisfaction guaranteed!
Buying an item, you have lifetime support and service like free collimation, explanation how to do collimation by yourself at home easily (noone in world wont give you such explanations supported with pictures), and you get free lifetime cleaning or any repair if needed if I can fix.
https://s15.postimg.org/4stf6ldq3/IMG_20160826_23534.jpg
https://s15.postimg.org/rdc7ke6t7/IMG_20160826_22740.jpg
https://s10.postimg.org/jwl295k61/IMG_20160826_23730.jpg
Contact denis0007dl att gmail.com
