For sale Carl Zeiss BLACK matted binoviewer, already Supercharged, and modified!
Item is in like new condition, optically and mechanically, and supports Baader GPC connection on back side.
In life it looks much more impressive than in pictures!
Eyepeice holders are Baaders 1.25 inch with compression ring, which allow fine focussing option, Baader catalog number BA2458125.
All optics have latest and best multicoatings from Zeiss.
Mechanics works extremly shooth and precise.
Collimation if needed can be done very easily with only simple shifting eyepeice holders, so no need shifting and touching prisms, which is common problem with Mak V.
This unit is already Supercgarged!
With Supercharge service:
--you absolutely do not loose in opticall performance
--performance is not affected by anything like internal reflections and simillar
--opticall performance is improved a LOT, and you get much more Clear Aperture on your binoviewer
--you can catch more light from your fast scopes
--you are able using longer focal lenght eyepeices with bigger FOV.
Specifications are:
---30mm prisms
---on left eyepiece side there is 30mm CA prisms (Supercharged), while on Mark V it is 28mm CA
---on right eyepiece side there is 28mm CA prisms(Supercharged), while on Mark V it is 26mm CA
---on telescope side you have full 30mm CA prisms (Supercharged), while on Mark V it is 28mm CA
---T2 connection on the telescope side
---all metal design
---easy collimation possible
Buying an item, you have lifetime support and service like free collimation, explanation how to do collimation by yourself at home easily (noone in world wont give you such explanations supported with pictures), and you get free lifetime cleaning or any repair if needed if I can fix.
Real Carl Zeiss optics and mechanics, so no compromise!
Satisfaction guaranteed!
Price 1090 EUROS include PayPal fees and fully tracked airmail worldwide shipping.
https://s13.postimg.org/ttsrthnvr/IMG_20160823_22428.jpg
https://s4.postimg.org/6iny8yyfx/IMG_20160823_23244.jpg
https://s10.postimg.org/j3ocin7k9/IMG_20160823_22190.jpg
https://s14.postimg.org/twuxuaxw1/IMG_20160823_22644.jpg
https://s9.postimg.org/ewohggxcv/IMG_20160823_22972.jpg
Contact denis0007dl att gmail.com
Kind regards and all best
Denis, binoviewers expert
