For sale amazing and unique 20x100 Magnesium body binoculars.
Bino provide amazing and incredible space views.
This binocular is result combining two binoculars together. To make this binocular, I must buy Omegon Argus 16x70, and Omegon argus 25x100 all Magnesium body binoculars. I replaced-switched only front part-plate, which holds eyepieces and prisms. As result, 20x100 Magnesium body binocular is born.
There are 3 different setups possible to look through:
1. original setup with original diopters and original rubber eyeguards
2. after removing original diopters and eyeguard, simply add additionally bought winged rubber eyeguards, and you get more comfortable views (fourth and fifth images in add)
3. my favorite one: after removing all arround eyepieces, you get amazing FLOATING like effect, with HUGE 65.6 degrees field of view (see last image). Eyepieces seems to dissapear, and HUGE space images are projected in front of you!
I also removed all rubber arround bino, so I get MUCH lighter overall construction, with smaller overall size, smaller lenght and widith.
Specifications:
---whole Magnesium body
---HUGE 65.6 DEG FOV
---large 20mm eye releaf (suitable for eyeglas wearers)
---BAK-4 prism: provides clear views thanks to a highly transparent prisms
---removable metal threaded tripod connector
---possible easy collimation from outside (same like in all BA8 series binoculars)
---accepts 1.25 inch filters on eyepeices
---lenght: 374mm (vs originally 390mm)
---widith: 262mm (vs originally 270mm)
---weight: 3050 grams ONLY (vs originally 3850 grams)
My price for item is 511 Euros with included PayPal fees and shipping worldwide, which on end stays me clean approx 445 Euros after PayPal takes fees and after I pay shipping. To make this binocular, I spent approx 1400 Euros, after buying two binoculars, paying shipping, additionally buying winged rubber eyeguards, getting binocualr to sand blasting, and replacing front bad original screws with much stronger and better INOX ones (check pictures taken from front).
https://s32.postimg.org/eyx0wvz51/DSC_0806.jpg
https://s31.postimg.org/n2qnydqiz/DSC_0792.jpg
https://s32.postimg.org/huar4r9kl/DSC_0793.jpg
https://s31.postimg.org/l75kulgob/DSC_0796.jpg
https://s32.postimg.org/s62w6fkxx/DSC_0815.jpg
https://s31.postimg.org/5bjyiyy4b/DSC_0812.jpg
Contact denis0007dl att gmail.com
