👍Svbony SV241 PRO Teleskop Power Management Box, USB3.0+DC Fotografie Astronomie Stromversorgung Controller Adapter
  • [W9193B] Astro Power Controller for Astrophotography, Plug and Play, SV241 Pro SVBONY
    [W9193B] Astro Power Controller for Astrophotography, Plug and Play, SV241 Pro SVBONY [W9193B] Astro Power Controller for Astrophotography, Plug and Play, SV241 Pro SVBONY [W9193B] Astro Power Controller for Astrophotography, Plug and Play, SV241 Pro SVBONY [W9193B] Astro Power Controller for Astrophotography, Plug and Play, SV241 Pro SVBONY [W9193B] Astro Power Controller for Astrophotography, Plug and Play, SV241 Pro SVBONY [W9193B] Astro Power Controller for Astrophotography, Plug and Play, SV241 Pro SVBONY [W9193B] Astro Power Controller for Astrophotography, Plug and Play, SV241 Pro SVBONY [W9193B] Astro Power Controller for Astrophotography, Plug and Play, SV241 Pro SVBONY [W9193B] Astro Power Controller for Astrophotography, Plug and Play, SV241 Pro SVBONY [W9193B] Astro Power Controller for Astrophotography, Plug and Play, SV241 Pro SVBONY [W9193B] Astro Power Controller for Astrophotography, Plug and Play, SV241 Pro SVBONY [W9193B] Astro Power Controller for Astrophotography, Plug and Play, SV241 Pro SVBONY [W9193B] Astro Power Controller for Astrophotography, Plug and Play, SV241 Pro SVBONY [W9193B] Astro Power Controller for Astrophotography, Plug and Play, SV241 Pro SVBONY [W9193B] Astro Power Controller for Astrophotography, Plug and Play, SV241 Pro SVBONY [W9193B] Astro Power Controller for Astrophotography, Plug and Play, SV241 Pro SVBONY [W9193B] Astro Power Controller for Astrophotography, Plug and Play, SV241 Pro SVBONY [W9193B] Astro Power Controller for Astrophotography, Plug and Play, SV241 Pro SVBONY
    [W9193B] Svbony SV241 PRO Teleskop Power Management Box, USB3.0+DC Fotografie Astronomie Stromversorgung Controller Adapter
    • 7x 12V DC-Ausgänge, regulierte Schnittstellen, und die Schalter-Interfaces 1-5 sind einzeln ein- und ausschaltbar;
      Der USB-Anschluss kann mit Guiding-Kameras, Planeten-Kameras usw. verbunden werden; der DC-Anschluss unterstützt DSO-Kühlkameras, Montierungen, elektronische Fokussierer, motorisierte Filterräder und elektronische Flattener; die PWM1-2 Ports dienen zum Anschluss von Taukappenheizungen.
      Echtzeit-Erkennung von Umgebungstemperatur und Luftfeuchtigkeit zur automatischen Temperaturregelung während des gesamten Betriebs.
    • Dieser Ferncontroller unterstützt ASCOM-Treiber und lässt sich nahtlos in die Astrofotografie-Software NINA integrieren. Nach dem Anschluss können alle Ausgangsports und Sensordaten der Powerbox direkt über die NINA-Oberfläche zentral überwacht und gesteuert werden.
    • Jeder USB-Power-Port liefert 5V bei 2,5A mit Überstromschutz bei 2,75A; die 5V-Leitung verfügt über Rückstrom- und Kurzschlussschutz, unabhängige MLCC-Filterung und 15KV ESD-Schutz (elektrostatische Entladung).
    • Ausgestattet mit einer T+H-Schnittstelle zur Erfassung von Luftfeuchtigkeit (5 % – 85 % relative Luftfeuchtigkeit), zur Berechnung des Taupunkts und zur Steuerung der Heizung; die Temp-Schnittstelle überwacht in Echtzeit die Temperatur von Heizbändern (-10°C bis 50°C) für präzise Temperaturregelung und Tau-Schutz.
    Hersteller : Svbony
    Artikelnummer : W9193B
     Fragen zum Artikel oder Lieferzeit?
    Preis: 169,00 € inkl. MwSt. 19% (Deutschland)
    7x 12V DC-Ausgänge, regulierte Schnittstellen, und die Schalter-Interfaces 1-5 sind einzeln ein- und ausschaltbar;Der USB-Anschluss kann mit Guiding-Kameras,…
    www.apm-telescopes.net
