Jagt auf die tiefe H-2A Raketen
  • (Entschuldige für der Englische Tekst)
    subject: Hunting the lower orbit H2A rockets
    _____________________________________________
    neues Bild:
    http://www.cloudynights.com/ub…t_20080625_023347akt1.jpg
    http://www.cloudynights.com/ub…H2Arocket_20080625cts.jpg
    http://www.cloudynights.com/ub…H2Arocket_20080625bt1.jpg
    http://www.cloudynights.com/ub…H2Arocket_20080625ats.jpg
    From most for the observers visible rocket stages,I pointed out that
    the Japanese H-2A rockets may be the most interesting,as their dimensions
    are a good 13.5m x 2.5m.General problem with rocket bodies is that
    the lower orbit bodies are often small and not very interesting with
    dimensions of around 2.5m x 2.5m,making them appear as just disks,even
    with highest possible resolution.There are some rocket stages with
    around 8 meter in length(Titan upper stages)and some with 10 meter,but
    these are in relatively high orbit(mostly round 800-900km)Most H-2A bodies
    are in high orbit as well,but 2 interesting exceptions are the rockets
    which carried the IGS-3A and IGS-4 spy-satellites.These move in orbits
    considerably below 500km,making them more interesting to hunt.(the spinning
    fairings E and F of the IGS-4 rocket can be seen often as flashing satellites).
    Attached is the final observation,I managed on June 25,after several nights of
    overcomming problems.An important problem for such lower orbit objects is
    their relative fast dimming when they depart in the Earths shadow.
    Most passes of either IGS-3R or-4R couldn't that way be tracked until culmination
    when the distance is closest.Exactly what I expected though,the elongated
    shape is clearly visible in all frames,even when we see the body probably
    slant side-on.
    For observers interested in the difficulty of imaging these objects,
    I have created the following simulation.It shows different stages of
    unsharpness,caused by effects of either bad seeing or limited resolution
    of the optical system.The file on top shows a rocket body with dimensions
    of a H-2A as seen from an optimal angle,showing full length.The lower file
    presents a situation as we see it slant side-on,showing not the full
    length in proportion to its width.the simulation at left shows the dimensions
    of the body like we would see it in perfect resolution,without any optical
    or atmospheric limits.Only a slight blurring caused by atmospheric or optical
    effects is necessary to see the situation presented in the mid.This can be
    compared to what a good telescope approximately shows in good seeing.
    In the worst case,you will only see a narrow elliptical or even round image
    as presented in the righter example.Note that most rocket bodies are even
    shorter in proportion.
    Simulation:
    http://img237.imageshack.us/im…ketbodysimulation2eq5.jpg
    Best regards,
    Ralf Vandebergh
  • Damn!
    The aliens left their mummies in our Orbit! Maybe this are living creatures, like some kind of alien-larvae?
    Congratulations Ralf, good shoots! [:D][:D][:D]
    Ei,ei,ei.... was hatte ich denn in meiner alten Signatur stehen?
    sternengedönsige clear sky Grüsse,
    Robert aus dem Allgäu
  • Besten Dank!
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">Zitat:<hr height="1" noshade id="quote"><i>Original erstellt von: sweeper</i>
    <br />Damn!
