Carl Zeiss sharpest binoviewer *LIMITED EDITION*
  • ONLY 1 PIECE AVAILABLE!!
    Beautifull, unique, LIMITED EDITION, airbrush painted!!
    Thats tottaly NEWLY IMPROVED version of Carl Zeiss sharpest binoviewer!
    Whats improved?
    1. ALU T2 male adapters on each eyepeice side! Each user can switch between any T2 photo and/or visual desirable equipment! It is possible even to combine sides, where on one eyepeice side, you can use eyepeices, and on other side you can use some quality cameras, or any other equipment you want! That turns binoviewer to multi-universal system
    2. easy collimation can be done by end user
    3. INOX T2 bayonet on telescope side
    Binoviewer is suitable for most demanding observers!
    It provide ULTRA SHARP images of any observed object, both daytime or at night sky!
    Its best possible addition to your premium APO, Newton, Mak Newt or any other telescope!
    Collimation is setted on 100%, and can be done very easily by end user!
    Speciications:
    - high quality all metal binobody
    - easy collimation possible by end user - collimation instructions included with purchase
    - high quality mirrors, scratch proof, highest light relection - Carl Zeiss made precision
    - beamsplitter made by German Schott glass
    - precisely polished all glass surfaces
    - high light transmittion
    - beamsplitter and mirrors diameter 25mm
    - 23mm Clear Aperture on each eyepeice side
    - 23mm Clear Aperture on telescope side
    - no annoying polarisation effect like common binoviewers have
    - T2 bayonet connection on telescope side
    - IPD: from 55mm to 75mm
    - light path: 13.6cm with included Baader eyepeice holders
    - weight: 600 grams with all included equipment
    Optics and mechanics Made in Germany!
    In setup are included:
    -1x Carl Zeiss Sharpest binoviewer
    -2x custom made T2 ALU plates on each eyepiece side
    -2x Baader eyepiece holders with adjustable diopters
    -1x custom made INOX T2 bayonet on telescope side
    -1x Baader Quick Changer
    -1x Baader T2 to 1.25 inch telescope adapter - accepts Baader Glass Path Correctors
    -2x 1.25 inch plastic female protective covers for front side of binoviewer
    -1x 1.25 inch plastic male protective cover for back side of binoviewer
    I cover shipping anywhere worldwide.
    Included lifetime support and collimation instructions.
    Price 1190 euros shipped.
    Contact me directly on email denis0007dl et gmail.com or via PM.
    Kind regards and all best
    Denis, binoviewers expert
