You are looking for high end, high quality binoviewer?
Here you go!
Every binoviewer can be very easily collimated if needed by end user!
Collimation is done beore shipping!
Binoviewer number 1.
Carl Zeiss Supercharged binoviewer - 30mm prisms
Specifications:
- custom made T2 male adapters on each eyepeice side
- all prims system inside - additionally BLACKENED
- prisms diameter 30mm
- 30mm Clear Aperture (SUPERCHARGED), instead 28mm Clear Aperture originally on left eyepeice side
- 28mm Clear Aperture (SUPERCHARGED), instead 26mm Clear Aperture originally on right eyepeice side
- 30mm Clear Aperture (SUPERCHARGED), instead 28mm Clear Aperture originally on telescope side
- NO ANNOYING POLARISATION EFFECT LIKE COMMON BINOVIEWERS HAVE
- IPD: 55mm to 75mm
- weight: 700g with all showed in DELUXE setup
Binoviewer number 2.
Carl Zeiss sharpest binoviewer
Specifications:
-custom made T2 male adapters on each eyepeice side
- highest quality mirrors, scratch proof, with highest light transmittion, with 25mm diameter, and 23mm Clear Aperure on each eyepeice side
- highest quality cube beamsplitter with 25mm diameter, and 23mm Clear Aperure on scope side
- weight: 600g with all showed in DELUXE setup
- IPD: 55mm to 75mm
Binoviewers number 3.
Carl Zeiss BIG binoviewer worldbest unit (two models: with or without rubber arround bino. Optics and mechanics same)
Specifications:
- best Zeiss avaiable multi-coatings
- egzotic prisms material - provide crystal clear look through bino with feeling like glass disappear
- prisms extrememly polished
- prisms edges additionaly blackened
- 31.5mm Clear Aperture prism on right eyepiece side
- 30mm Clear Aperture prism on left eyepiece side
- 29mm Clear Aperture prism on telescope side
- high quality INOX T2 bayonet on telescope side
- IPD: 54mm to 82mm
- weight: 950g with all showed in DELUXE setup
I offer you 2 different setups or each binoviewer:
Setup No. 1. BASIC SETUPS here reduce price 275 USD, and what is included is:
-1x Premium Carl Zeiss binoviewer
-2x custom made T2 plates on each eyepiece side
-1x INOX T2 bayonet on the telescope side
-2x 1.25 inch plastic female protective covers for front side of binoviewer
-1x 1.25 inch plastic male protective cover for back side of binoviewer
Setup No. 2. DELUXE SETUPS, like showed on pictures which includes:
-2x Baader ClickLock eyepiece holders
-1x Baader Heavy Duty Quick Changer
-1x Baader T2 to 1.25 inch telescope adapter
Optics and mechanics Made in Germany!
Excellent condition!
Included lifetime support and free collimation instructions!
Conatct me via PM or via email denis0007dl et gmail.com
Kind regards and all best
Denis, binoviewers expert
