One more piece available today!
That is tottaly NEWLY IMPROVED version of famous Carl Zeiss world sharpest binoviewer, with cube beamsplitter and mirrors inside!!
What is improved in this version?
1. there are additionally custom made, CNC machined, expensive and high quality metal T2 male adapters on each eyepeice side! Because that option, each user can switch between any T2 photo and/or visual desirable equipment! It is possible even to combine sides, where on one eyepeice side, you can use eyepeices, and on other side you can use some quality camera, or any other equipment you want! No other binoviewer can do that!! That turn binoviewer to multi-universal system!!
2. becasue custom made T2 adapters, very easy collimation can be done by shifting these adapter plates! Once collimation is achieved, it stays SUPER STRONG in place
3. there is additionally custom made, CNC machined high quality INOX T2 bayonet on telescope side
4. added a pair of expensive and popular Baader ClickLock adapters as eyepeice holders which can be very easily replaced
5. included Baader Heavy Duty T2 QuickChanger - much stronger holding of binoviewer vs previous included model, and there are finally ZERO marks on your binoviewer, while previously included cheaper model leaves set screw marks on binoviewer T2 bayonet!
Binoviewer is MODIFIED!
This binoviewer is suitable for most demanding observers!!
It provide ULTRA SHARP images of any observed object, no matter if you observe at daytime or at night sky!!
Its excellent and best possible addition to your premium APO, Newton, Mak Newt or any other telescope!
Collimation is setted on 100%, and if needed to adjust, can be done very easily with only simple shifting eyepeice holders plates!
Specifications:
- highest quality mirrors, scratch proof, with highest light transmittion, with 25mm diameter, and 23mm Clear Aperure on each eyepeice side
- highest quality cube beamsplitter with 25mm diameter, and 23mm Clear Aperure on scope side
- NO ANNOYING POLARISATION EFFECT LIKE COMMON BINOVIEWERS HAVE
- custom made, CNC machined, expensive and high quality metal T2 male adapters on each eyepeice side - multi-universal system
- very popular Baader 1.25 inch ClickLock eyepeice holders
- possible fine diopter adjustment on each eyepeice side
- custom made CNC machined, highest quality INOX made T2 bayonet on telescope side
- weight: 600g only with intalled Baader ClickLock eyepeice holders
- IPD (interpupilar distance): from 55mm to large 77mm
I offer you 2 different setups:
Setup No. 1. BASIC SETUP, price 950 USD:
-1x Premium Carl Zeiss binoviewer
-2x custom made T2 plates on each eyepiece side
-1x INOX T2 bayonet on the telescope side
-2x 1.25 inch plastic female protective covers for front side of binoviewer
-1x 1.25 inch plastic male protective cover for back side of binoviewer
Setup No. 2. DELUXE SETUP, price 1198 USD:
-2x Baader ClickLock eyepiece holders
-1x Baader Heavy Duty Quick Changer
-1x Baader T2 to 1.25 inch telescope adapter
Optics and mechanics Made in Germany!
Excellent condition!
I cover shipping anywhere wordwide!
Included lifetime support, free cleaning, free collimation, and I can provide you free collimation instructions if needed!!
Contact me to denis0007dl et gmail.com
Kind regards and all best
Denis, binoviewers expert
