18 pieces were available for sale
(8 pieces sold so far)
I had luck to found and pick up all USA stock of these items with excellent optics and mechanics, so these are very last items after I pick up, made and sold all European items!
Thats most successful, most selling, Carl Zeiss binoviewers ever!!
Not without reason: prisms big enough, and VERY low price, and most important, high quality optics and mechanics, all Made in Germany!!
Excellent optical and mechanicall condition!
Mechanics works shooth and precise!
Collimation is setted on 100%, and if needed to adjust, can be done very easily with simple shifting eyepeice holders plates!
Binoviewer is already SUPERCHARGED and MODIFIED!
That is tottaly NEWLY IMPROVED version!
What is improved in this version?
1. additionally custom made expensive, high quality ALU T2 male adapters on each eyepeice side! Because that, each user can switch between any T2 photo and/or visual desirable equipment! It is possible even to combine sides, where on one eyepeice side, you can use eyepeices, and on other side you can use some quality cameras, or any other equipment you want! That turns binoviewer to multi-universal system
2. becasue custom made T2 adapters, very easy collimation can be done by shifting these adapter plates! Once collimation is achieved, it stays SUPER STRONG in place
3. additionally custom made highest quality INOX T2 bayonet on telescope side which support popular Baader Glass Path Correctors (GPC)
4. tottaly newly repainted whole binobody
Specifications:
- high quality all metal design of binobody
- high quality all prisms
- high quality polished all prism surfaces
- high light transmittion
- easy collimation possible
- all prisms edges additionally BLACKENED
- prisms diameter 25mm
- 25mm Clear Aperture (SUPERCHARGED), instead 23mm Clear Aperture originally on left eyepeice side
- 25mm Clear Aperture (SUPERCHARGED), instead 23mm Clear Aperture originally on right eyepeice side
- 25mm Clear Aperture (SUPERCHARGED), instead 23mm Clear Aperture originally on telescope side
- NO ANNOYING POLARISATION EFFECT LIKE COMMON BINOVIEWERS HAVE
- bino have 2 air-to-glass surfaces less than any other binoviewer made for astronomy on market, and this results with better light transmittion, less scattered light, more sharpness, and much more contrast
- CUSTOM MADE, HIGHEST QUALITY INOX T2 bayonet on the telescope side - (accepts Baader Glass Path Correctors).
- IPD (interpupilar distance): from 55mm to 75mm
I offer you several different setups:
Setup No. 1. BASIC SETUP, price 334 EUROS with included fully tracked shipping anywhere worldwide:
-1x Supercharged Carl Zeiss binoviewer
-2x custom made T2 plates on each eyepiece side
-1x INOX T2 bayonet on the telescope side (accepts Baader Glass Path Correctors)
-here you can buy/add any T2 eyepeice holders you want like Baader ClickLocks, or Baader Helicall, or Baader Ultrashort, or Blue self centring etc.
Setup No. 2. DELUXE SETUP, price 575 EUROS with included fully tracked shipping anywhere worldwide:
-2x Baader ClickLock eyepiece holders
-1x Baader Heavy Duty Quick Changer
-1x Baader T2 to 1.25 inch telescope adapter
-2x 1.25 inch plastic female protective covers for front side of binoviewer
-1x 1.25 inch plastic male protective cover for back side of binoviewer
Supercharge certificate included and signed by me (showed on picture in ad).
I cover shipping anywhere worldwide for any setup!
Included lifetime support, free cleaning, free collimation, and I can provide you free collimation instructions if needed!!
Real Carl Zeiss optics and mechanics, so no compromise!
Satisfaction guaranteed!
Contact me via forum or directly via email denis0007dl et
gmail.com
Kind regards and all best
Denis, binoviewers expert
