Der Champagner fliesst im Astrosurf!
Die elsässische Astroamateurin Claudine Rinner hat vor kurzem den neuen Kometen P/2011 W2 Rinner entdeckt (mag 17,6).
Hier die Bestätigungsmeldung >
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">Zitat:<hr height="1" noshade id="quote">Electronic Telegram No. 2922
Central Bureau for Astronomical Telegrams INTERNATIONAL ASTRONOMICAL UNION CBAT Director: Daniel W. E. Green; Hoffman Lab 209; Harvard University;
20 Oxford St.; Cambridge, MA 02138; U.S.A.
e-mail: mailto:cbatiau%40eps.harvard.edu (alternate mailto:cbat%40iau.org) URL http://www.cbat.eps.harvard.edu/index.html
Prepared using the Tamkin Foundation Computer Network
COMET P/2011 W2 (RINNER)
Claudine Rinner, Ottmarsheim, France, reports her discovery of a comet with a 1' tail in p.a. 293 degrees on CCD images taken with a 0.5-m f/3 reflector located at the Oukaimeden Observatory near Marrakech, Morocco (discovery observations tabulated below). After posting on the Minor Planet Center's NEOCP webpage, numerous other CCD astrometrists have also commented on the object's cometary appearance from images obtained during Nov. 29.3-29.5 UT. H. Sato (Tokyo, Japan; remotely using telescopes at the RAS Observatory near Mayhill, NM, U.S.A.) writes that exposures taken with a 0.25-m f/3.4 reflector in bad seeing show magnitude 17.6 without an obvious coma, but with an obvious tail 20"
long in p.a. 275 deg; exposures taken with a 0.51-m f/4.5 reflector show a 13" coma and the same tail dimensions. R. Ligustri (Udine,
Italy) also used a 0.25-m f/3.3 reflector remotely at the RAS Observatory near Mayhill to find a coma elongated toward p.a. 270 deg (size 33"). E. Guido, G. Sostero, and N. Howes write that stacked images taken remotely with a 0.25-m f/3.4 reflector at the GRAS Observatory near Mayhill show a diffuse coma nearly 15" in diameter. J. V. Scotti reports that images taken with the Spacewatch 1.8-m f/2.7 reflector (+ Schott OG-515 filter, spanning V + R + I; pixel size 0".62) shows a diffuse coma of diameter 7" with a tail extending
0'.30 in p.a. 289 deg. G. Hug (Scranton, KS, U.S.A., 0.56-m reflector) notes a broad tail extending 1' in p.a. 285 degrees.
2011 UT R.A. (2000) Decl. Mag. Observer
Nov. 28.12723 7 57 45.14 + 5 36 54.5 17.9 Rinner
28.14138 7 57 45.27 + 5 36 45.8 18.0 "
28.15552 7 57 45.36 + 5 36 37.2 17.9 "
28.16967 7 57 45.50 + 5 36 28.3 17.9 "
The available astrometry, the following very preliminary elliptical orbital elements by G. V. Williams, and an ephemeris appear on MPEC 2011-W80.
T = 2011 Oct. 10.616 TT Peri. = 210.504
e = 0.51202 Node = 233.758 2000.0
q = 2.31556 AU Incl. = 14.202
a = 4.74524 AU n = 0.095349 P = 10.3 years
NOTE: These 'Central Bureau Electronic Telegrams' are sometimes superseded by text appearing later in the printed IAU Circulars.
(C) Copyright 2011 CBAT
2011 November 29 (CBET 2922) Daniel W. E. Green
und die ersten Bilder von Jean-François Soulier >
http://6888comete.free.fr/fr/imageNEOcrAK174france.htm
Gruss,
